Bad proportioning valve.. any ideas? - JeepForum.com
post #1 of 11 Old 11-11-2010, 11:58 PM Thread Starter
tonythehazelnut
After extensive brake work on this truck ('99, 4.0L, 4spd auto and 2wd), I went to bleed the brakes and was getting no pressure at the front passenger tire. I disconnected the banjo bolt from the caliper, hung the hose free, pumped up the brakes... no fluid came out. Disconnected the steel line, no fluid. Disconnected the steel line from the proportioning valve, no fluid. I removed the valve, cleaned it out, and I'm gonna try to put it back on. Any tips on how to free up an old valve? If I gotta get another one from the junkyard, which proportioning valves from other vehicles would work? I hope this all makes sense, I'm freaking tired
Built Not Bought #482
AN ARMED SOCIETY IS A POLITE SOCIETY
tonythehazelnut is offline
post #2 of 11 Old 11-23-2010, 10:15 PM
Heap-O-Jeep
Heap-O-Jeep's Avatar
im kinda having the same problem with my cherokee. on hard braking it pulls left. dont know what it is i have fluid in the rh circuit new hoses and calipers,pads,rotors i have pressure i had an assistant work the pedal for bleeding. i used a prybar to try to move the wheels while he applied the brakes i couldn't move it im wondering if my prop. valve is going bad. a friend of mine had a 97 TJ with a faulty prop.valve hmm wondering if there is something to this.
WHY DO YOU NEED TO KNOW WHERE YOU ARE GOING?
Heap-O-Jeep is offline
post #3 of 11 Old 11-23-2010, 10:37 PM
mjjeeper
1988 MJ Comanche
Does the truck still have the height sensing brake line bracket and line connected into the prop valve?
mjjeeper is offline
post #4 of 11 Old 11-23-2010, 10:44 PM
Heap-O-Jeep
huh? obviously this is something im not aware of ?
post #5 of 11 Old 11-24-2010, 08:13 AM
mjjeeper
1988 MJ Comanche
MJ's had a height sensing rear proportional valve. A braket came down from the frame with a rod connecting it to a braket on the rear axle housing diff cover. (It was supposed to sense the load u were carrying and apply increased brake pressure to the rear wheels depending on the wieght in the bed) look up under the truck by the rear axle and above to see if you have any remnants of the device. An additional brake line runs to that. btw, mj brakes are a *****. when i did mine i had the same type of problems; i ended up replacing everything after being frustrated with what it could be. (brake booster/prop valve included) I do not have my height sensing prop valve hooked up either. I believe also if you switch out your prop valve in the front to an xj style without the additional line running to the rear it cuts it out of the system
mjjeeper is offline
post #6 of 11 Old 11-24-2010, 12:01 PM
Pete M
1988 MJ Comanche
the front is not a "prop" valve, it's just a splitter. the proportioning duties are carried out by the height sensing prop valve in the rear.
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email:
ComancheClub.com/forums
Pete M is offline
post #7 of 11 Old 11-24-2010, 03:19 PM
Heap-O-Jeep
ok. yeah i know what that is. i have never experienced it on a jeep, (i have seen it on other vehicles) but i trust that there is one on the MJ. but this post is in the commanche forum but the original poster has a YJ? so....... where do we go from here?
post #8 of 11 Old 11-24-2010, 04:54 PM
mjjeeper
1988 MJ Comanche
Why do you need to know where you are going??? lol. i couldnt resist.
Umm is everything new on the left side too?
mjjeeper is offline
post #9 of 11 Old 11-24-2010, 07:27 PM
Heap-O-Jeep
yes new calipers and hoses pads rotors!
post #10 of 11 Old 11-24-2010, 09:52 PM
mjjeeper
1988 MJ Comanche
Nothing leaking? maybe brakes? Maybe front steering/suspension? all good tie rod ends and trac bar bushings?
mjjeeper is offline
post #11 of 11 Old 12-08-2010, 11:21 PM
carnuck
1984 J-Series Truck
I bypassed the rear valve in mine. Moved the hose down to where the valve was attached and left the "extra" line off (capped it)
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
Proportioning valve question 88 mj Des88MJ XJ Cherokee Technical Forum 3 11-24-2009 08:24 AM
Proportioning Valve joshs1ofakindxj XJ Cherokee Technical Forum 4 05-29-2009 10:30 PM
'75 Cherokee Proportioning Valve? TheMyTChuck XJ Cherokee Technical Forum 6 01-08-2009 07:30 AM
Proportioning valve Q summitlt MJ Comanche Technical Forum 2 05-29-2005 02:22 PM
Proportioning valve question mbaucom XJ Cherokee Technical Forum 1 09-08-2004 02:37 PM
