4.0L Random Studdering - JeepForum.com
post #1 of 4 Old 04-29-2012, 08:01 PM Thread Starter
1989MJ
1989 MJ Comanche
I have a 1989 Comanche and I having a issue with my truck "studdering". It is not backfiring or anything like that and happens at idle and constant speeds. I also have noticed it happens when it is warmer outside. Im not sure if it is a CPS or mabye a ECU? I did a tune-up 18,000 miles ago. Suggestions?
1989MJ is offline
post #2 of 4 Old 04-29-2012, 09:17 PM
ftpiercecracker
1990 MJ Comanche
4.0? 2.5?
auto?
5spd?
4spd?
and give a little more detail about what EXACTLY it is doing when it studders.
ftpiercecracker is offline
post #3 of 4 Old 04-29-2012, 11:10 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
89 4.0.
Check your CPS output:
Renix CPS Testing and Adjusting
Renix CPSs have to put out a strong enough signal to the ECU so that it will provide spark.
Most tests for the CPS suggest checking it for an ohms value. This is unreliable and can cause some wasted time and aggravation in your diagnosis of a no-start issue as the CPS will test good when in fact it is bad.
The problem with the ohms test is you can have the correct amount of resistance through the CPS but it isn’t generating enough voltage to trigger the ECU to provide spark.
Unplug the harness connector from the CPS. Using your voltmeter set on AC volts and probing both wires in the connector going to the CPS, crank the engine over. It won’t start with the CPS disconnected.
You should get a reading of .5 AC volts.
If you are down in the .35 AC volts range or lower on your meter reading, you can have intermittent crank/no-start conditions from your Renix Jeep. Some NEW CPSs (from the big box parts stores) have registered only .2 AC volts while reading the proper resistance!! That’s a definite no-start condition. Best to buy your CPS from Napa or the dealer.
Sometimes on a manual transmission equipped Renix Jeep there is an accumulation of debris on the tip of the CPS. It’s worn off clutch material and since the CPS is a magnet, the metal sticks to the tip of the CPS causing a reduced voltage signal. You MAY get by with cleaning the tip of the CPS off.
A little trick for increasing the output of your CPS is to drill out it’s mounting holes with the first drill bit that just won’t fit through the original holes. Then, when mounting it, hold the CPS down as close to the flywheel as you can while tightening the bolts.
Revised 11-29-2011
And check your TPS on the engine side:
RENIX TPS ADJUSTMENT
Before attempting to adjust your TPS be sure the throttle body has been recently cleaned. It's especially important that the edges of the throttle butterfly are free of any carbon build-up.
IMPORTANT NOTE: Using the positive (red) lead of your ohmmeter, probe the B terminal of the flat 3 wire connector of the TPS. The letters are embossed on the connector itself. Touch the black lead of your meter to the negative battery post. Wiggle the wiring harness where it parallels the valve cover and also over near the MAP sensor on the firewall. If you see more than 1 ohm of resistance, or fluctuation in your ohms reading, some modifications to the sensor ground harness will be necessary. The harness repair must be performed before proceeding. I can provide an instruction sheet for that if needed.
MANUAL TRANSMISSION: RENIX manual transmission equipped XJs have a three-wire TPS mounted on the throttle body. This manual transmission vehicle TPS provides data input to the ECU. The manual transmission TPS has three wires in the connector and they're clearly embossed with the letters A, B, and C. Wire "A" is positive. Wire "B" is ground. Key ON, measure voltage from "A" positive to "B" ground by back-probing the connectors. Note the voltage reading--this is your REFERENCE voltage. Key ON, back-probe the connector at wires "B" and "C". Measure the voltage. This is your OUTPUT voltage. Your OUTPUT voltage needs to be seventeen percent of your REFERENCE voltage. For example: 4.82 volts X .17=.82 volts. Adjust the TPS until you
have achieved this percentage. If you can't achieve the correct output voltage replace the TPS and start over.
AUTOMATIC TRANSMISSION: RENIX automatic transmission equipped XJs has a TPS with two connectors. There is a flat three-wire connector, same as the manual transmission vehicles have, and it is tested the same as the manual transmission equipped vehicles—
FOR ENGINE MANAGEMENT RELATED ISSUES. However, the automatic TPS also has a square four-wire connector clearly embossed with the letters A,B,C, and D. It only uses three wires and provides information to the Transmission Control Module. Key ON, measure voltage between "A" positive and "D" ground. Note the voltage. This is your REFERENCE voltage. Back-probe the connector at wires "B" and "D". Measure the voltage. This is your OUTPUT voltage. Your OUTPUT voltage needs to be eighty-three percent of your REFERENCE voltage. For example 4.8 volts X .83=3.98 volts. Adjust the TPS until you have achieved this percentage. If you can't, replace the TPS and start over. So, if you have an automatic equipped XJ your TPS has two sides--one side feeds the ECU, and the other side feeds the TCU.
If you have TRANSMISSION issues check the four-wire connector side of the TPS.
If you have ENGINE issues check the three-wire connector side of the TPS. For those with a MANUAL TRANSMISSION--the TPS for the manual transmission XJs is stupid expensive. You can substitute the automatic transmission TPS which is reasonably priced.
Revised 04-08-2012
cruiser54 is offline
post #4 of 4 Old 04-30-2012, 10:27 AM Thread Starter
1989MJ
1989 MJ Comanche
Thanks crusier! Ill be sure to check the CPS and yes it is a 4.0L 5 spd 2wd automatic. It seems to almost give no spark for one cylinder then go back to normal running conditions. So its like a miss but i will check the CPS and see where tht takes me
1989MJ is offline
4.0 liter , comanche
Studdering problem in 4.0 vector10 XJ Cherokee Technical Forum 9 04-21-2012 08:40 PM
studdering while driving whiteys_red_XJ XJ Cherokee Technical Forum 2 11-14-2010 03:52 PM
studdering and stalling. HELP PLEASE! wyatts95xj XJ Cherokee Technical Forum 2 10-12-2009 01:21 PM
studdering or missing idk??? fordpower XJ Cherokee Technical Forum 2 11-25-2005 05:46 PM
87 2.5 studdering on the road eliguy XJ Cherokee Technical Forum 5 11-05-2003 08:27 AM
