1987 commanche no fuel from injector - JeepForum.com
post #1 of 4 Old 05-23-2014, 06:38 PM Thread Starter
Benhojo
Hi I just bought a 1987 jeep Comanche, has a 2.5 TBI, automatic trans. Got a used motor cause original was toast. Only difference with the used was it was manual trans, so changed flywheel. Got everything in, all lines, connections correctly installed. Problem is I'm not getting spray from the injector. It has spark, verified timing is correct, swapped TBI unit from original engine that was running still nothing. Any ideas? Checked fuel pressure at TBI unit too, was ok.
Benhojo is offline
post #2 of 4 Old 05-24-2014, 07:58 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I would begin by doing posts 1 through 3 in my link below.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #3 of 4 Old 05-26-2014, 07:44 PM Thread Starter
Benhojo
Thanks cruiser54, turned out to be broken wire leading to injector. Did end up cleaning out all the tar from main connector.
Benhojo is offline
post #4 of 4 Old 05-26-2014, 09:56 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Very cool result!! Glad to hear it.
2.5 , 2wd , comanche , fuel injector , TBI
