1987 Comanche Problems - JeepForum.com
post #1 of 11 Old 09-11-2006, 07:40 PM Thread Starter
shelby_Extreme
Need More Mud.....
shelby_Extreme's Avatar
Hey Everyone
I have a 1987 Jeep Comanche 4.0L that is giving me a headache and I can't get it running again. My little brother replaced plugs, wires,cap,rotor, and since then it will not run. It has good fuel pressure,good spark,and cranks over nicely but it doesnt even try to run. I desprately need help where as this vehicle has to be on the road in 2 weeks.
Has anyone had this happen to them??
Thanks for any information!
1999 Jeep Cherokee Sport 2dr 2" Lift and 31's -- DAILY DRIVER
1993 Jeep Cherokee Sport 4dr 2" Lift and 31's -- WINTER BEATER
1983 Honda CM450E -- 92MPG
1998 Jeep Cherokee Sport 2dr 2" Lift and 31's --ROLLED & TOTALED
shelby_Extreme is offline
post #2 of 11 Old 09-12-2006, 04:28 PM Thread Starter
shelby_Extreme
Need More Mud.....
Originally Posted by 4.7 MJ
Start with checking the plug wires fireing order...
we checked that and its good
post #3 of 11 Old 09-12-2006, 10:08 PM
Country Jeep
Comanche Kemosabe
Country Jeep's Avatar
Good fuel pressure, good spark, turns over, and fireing order is correct. And it doesn't even try to start to run on it's own power?
Odd...timing??
Main rig under screen-name...
, 4.0L HO I6, AW4. Daily driver.
'98 XJ Classic (moss green) 2WD, 4.0L HO I6, AW4. Restoration project.
Gone, but not forgotten:
, '94 ZJ Limited, '85 CJ7,
Blue Jeep Club Member #113
Country Jeep is offline
post #4 of 11 Old 09-13-2006, 06:14 AM
jfiscus
jfiscus's Avatar
1993 XJ Cherokee
Could the parts store have sold you the wrong cap/button?
93 Grand Cherokee 6.0L auto
jfiscus is offline
post #5 of 11 Old 09-15-2006, 08:45 AM
scrapy
I have a 88 I4 4x4 cheif. It was giving me simular problems. The previous owner had the CPS sensor replaced. so that was the last thing i checked after changing TPS,plugs ,coil,ect . I finaly used 3 cans of brake cleaner on the CPS (crank shaft position sensor) then I used about 5 miniuts of air just to blow it off good. it seemed to do some good.
scrapy is offline
post #6 of 11 Old 09-28-2006, 04:08 PM
88XJSport
88XJSport's Avatar
1988 XJ Cherokee
He said he has spark, so that would rule out the cps.
88XJSport is offline
post #7 of 11 Old 10-09-2006, 05:03 PM
rebelmachine390
Guest
Well, something doesn't add up here then. If it has good spark, and good fuel, then all that is left is air and compression. Have you run a compression test? Did you break a timing chain on it? Cranking over nicely, like fast and easy? Good sign of no compression. Are the injectors energized? Have you check all the fuses?
rebelmachine390 is offline
post #8 of 11 Old 10-09-2006, 07:27 PM
Car RamRod
did the problem exist before the the tune up, or it started right after?
1986 Comanche, 4x4, 2.8l v6
1989 Mustang LX Coupe, h/c/i, bolt ons, 5lug
have to break in engine and trans, then hitting E-town and a dyno
Car RamRod is offline
post #9 of 11 Old 10-13-2006, 06:32 AM
grbjr87pioneer
1988 MJ Comanche
Having same type of problem
I have an 87 also, parked one night , won't start now. Changed plugs, wires, rotor, cap, CPS. got fuel BUT no spark.
Where do I go from here?
Rob
grbjr87pioneer is offline
post #10 of 11 Old 10-13-2006, 03:09 PM
Pete M
1988 MJ Comanche
Coil or ignition module?
Jeep on!
--Pete
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email:
ComancheClub.com/forums
Pete M is offline
post #11 of 11 Old 10-13-2006, 04:07 PM
grbjr87pioneer
1988 MJ Comanche
Checked coil, works on another jeep, Ignition mod next huh?
1987 Jeep Comanche Starting Issues billyshred MJ Comanche Technical Forum 6 11-10-2011 12:07 PM
1987 xj problems please help!! jeepcherokee85 XJ Cherokee Technical Forum 4 11-11-2008 01:58 PM
1987 jeep comanche 2x4 to 4x4 swap jeep95xj87mj MJ Comanche Technical Forum 0 03-22-2008 08:09 PM
1987 problems starting speke XJ Cherokee Technical Forum 8 07-30-2006 09:28 PM
1987 Comanche Pugouet Tranny Swap jduffy XJ Cherokee Technical Forum 0 11-06-2004 03:55 PM
