Won't start in 2wd. No Noise, No Click, but starts in 4wd low - JeepForum.com
post #1 of 4 Old 02-17-2021, 04:24 AM Thread Starter
Torin
Recently been having problems starting my 2010 2D Jeep Wrangler Manual.
When I go to start it in the morning all my lights turn on but I get no Noise, no clicking sound.
Recently stumbled on a post that mentioned trying it in 4wd low and it started right up.
What do you think could be the problem?
It was been low temperature the past few days, not sure if that could explain it.
Thanks in advance!
Torin is offline
post #2 of 4 Old 02-18-2021, 05:48 AM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
I would post this in the JK tech section. This one gets very little traffic.
https://www.jeepforum.com/forum/f96/
That said, I've never heard of a JK starting up in one t/case mode but not another. Sounds like a possible computer (TIPM) issue. First thing to try is always resetting all the systems by disconnecting the battery for 10 min. While you've got it disconnected, make sure the terminals on the battery and cables are good and clean.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #3 of 4 Old 02-18-2021, 08:13 AM
cranbiz
cranbiz's Avatar
Could be the neutral safety switch is bad. I believe that switch is inactive in 4Lo.
02 WJ Laredo, heavily optioned but stock
12 JK, 3.5" Teraflex/Franken lift, Bilstein 5100's, BFG KM3's 37x12.5/R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #4 of 4 Old 06-11-2021, 09:00 AM
BowPro73
BowPro73's Avatar
Mine wouldn't start in cold morning weather, but would start after the sun heated up things. Don't know if it was coincidental that yours started after engaging 4wd, or if it was finally warmer. Here's a video of what I tried and succeeded with. Worth a shot...
https://youtu.be/xL4hZ2vGY6E
BowPro73 is offline
