Simple test fixture for tracking short circuits - JeepForum.com
 3Likes
  • 1 Post By jay-h
  • 1 Post By JEEPFELLER
  • 1 Post By jay-h
post #1 of 10 Old 05-18-2020, 11:59 AM Thread Starter
jay-h
The problem with identifying shorts in wiring is they seem fine until they blow the fuse, giving you little guidance
Rig up a simple brake/signal bulb in a socket like this, terminate the ends of the leads with trimmed spade terminals. Remove the fuse and put this in its place. The advantage of this is that the bulb works as a current limiter as well as indicator... a dead sort will light the bulb at full normal brightness, but will not allow enough current to fry your wiring. Normal loads will produce reduced brightness.
Put a few feet of wiring on the fixture so that you can place the bulb in a visible location while working on the wiring
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #2 of 10 Old 05-19-2020, 04:36 PM
mukluk
mukluk's Avatar
Or you can just buy a ready made automotive test light, it's the exact same concept.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #3 of 10 Old 05-22-2020, 10:41 AM
gutthans
gutthans's Avatar
Yeah, but why spend $8 and up when all of us have junk, like these pieces, laying around?
gutthans is offline
post #4 of 10 Old 05-23-2020, 08:45 AM
V8GCZJ
Just use a meter and test continuity! Don't have to spend or "rig up" anything. I got plenty of them around.
V8GCZJ is offline
post #5 of 10 Old 05-25-2020, 01:41 PM Thread Starter
jay-h
The reason for using a light like this is that it puts a load on the circuit.
A volt/ohm meter (or for that matter a test light) will not clearly differentiate a legitimate tail light load and a dead short.
By placing a working load on the circuit, it becomes easier to identify when it is shorted yet will not allow overload on the wiring.
11-11-11 likes this.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
jay-h is offline
post #6 of 10 Old 08-27-2020, 03:40 AM
OldSpice69
Thanks for this guide!
OldSpice69 is offline
post #7 of 10 Old 09-17-2020, 08:27 PM
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
This puppy is also nice and really bright.
You can make your wire leads really long so you can place it where it can be seen well (when I used mine, no need to really see it straight on, the "lack of the light" is what we're after).
When it dies or flickers, the ambient light, or lack of, let's me know immediately that I have found the reason for so many fuses being blown (before I used this method)
Another thing to be aware of is the bulb gets really hot and will melt carpet/ seats/ plastic---so either watch where it's placed---or make some sort of cage around it similar to a drop light cage.
Using a test light may not be bright enough to make it EZ, if you use a meter, you or your helper must watch it constantly---a quick flicker may go unnoticed.
Light being on, the short is present (the fuse would have blown) The light can remain on with no damage occurring. The moment you shake/ move/ remove the short the light goes off. This really aids in longer term looking for the short. You are not just wasting fuses with no positive results!
jay-h,
I'm glad I'm to see I'm not the only one using this trick! Maybe it will catch on!
-----JEEPFELLER
JEEPFELLER is offline
post #8 of 10 Old 09-21-2020, 05:36 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
X2
And I can pierce insulation as well as throw it in the tool bag without worrying about breaking the bulb.
Paperwork will ruin any military force.
Chesty Puller
jeepdaddy2000 is offline
post #9 of 10 Old 09-21-2020, 05:02 PM
JEEPFELLER
JEEPFELLER's Avatar
1977 CJ5
The idea here is to use this set up as a NON-BLOWING FUSE and a ON/ OFF indicator while you search for the short by shaking crap or maybe using a test light or meter on the wiring.
----JEEPFELLER
post #10 of 10 Old 09-21-2020, 05:55 PM Thread Starter
jay-h
If you test a circuit with a DVM or a test light, a legitimate light bulb, as well as many other types of load will show as very low or zero ohms which makes them appear just the same as a short. Using a brake light bulb lets enough current through to partially activate the bulb, however it it's a normal bulb load, the brake light bulb will be dim. Only a short will light the brake light bulb to full brightness.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
jay-h is offline
