Quick and Easy chrome cleaner - JeepForum.com
post #1 of 6 Old 03-16-2020, 03:49 PM Thread Starter
JeepLiving
JeepLiving's Avatar
1976 CJ7
I was cleaning my chrome glove box cover and was using a mild scrub pad but it looked like it was leaving scratches. I remembered seeing one time that you can use Coke or Diet Coke with a piece of Aluminum foil to take off the rust. The first picture is the inside of the glove box as I was already cleaning the outside before thinking of putting this out there for someone else to try. The picture below is before cleaning the inside cover.
I then took a square of aluminum foil and Diet Coke and a bucket and poured some on the cover. I folded the aluminum foil in half twice and went to work on the cover. Right away black stuff was rolling off and I could see it was working. Put a little more Diet Coke on the cover and went over it again. Below you can see the result. I think the scratches are from the scrub pad I started using first.
I also did the outside and this already had some scratches in it so I'm not sure if any came from using the aluminum foil. I tried to rinse off the foil while using to flush off the dirt. You can see below that it turned out looking pretty good. If you are going to try this do it in a small area first. When I was done I washed it with soap and rinsed off. Once dry I used Turtle paste wax to seal it up.
Any day is a good day when you can get on the trails!
JeepLiving is offline
post #2 of 6 Old 03-30-2020, 12:14 PM
Nathan Hill
Great clean finish, overall. Thanks for the tip!
Nathan Hill is offline
post #3 of 6 Old 04-16-2020, 06:47 AM Thread Starter
JeepLiving
JeepLiving's Avatar
1976 CJ7
No problem. Hope it works for you.
JL
post #4 of 6 Old 07-29-2020, 11:59 AM
JoshIv
JoshIv's Avatar
Amazing work! Btw, I won't drink coke anymore...
JoshIv is offline
post #5 of 6 Old 07-30-2020, 07:57 PM
yellow85cj
yellow85cj's Avatar
The Coke "removes" the rust stains because it contains phosphoric acid. You can buy it at Home Depot in the paint section usually. If you have something rusty, soak it in the overnight and will clean the rust up. Can't recall the name it sells under. Gallon jugs bluish green liquid. Used a lot of it when I did my rebuild. Don't let the "acid " name worry you , it's not a skin burning thing.
Might try some No 7 chrome polish on the scratches, it is a polish not a wax so you will have to wax it after polishing.
yellow85cj is offline
post #6 of 6 Old 07-31-2020, 09:32 AM Thread Starter
JeepLiving
JeepLiving's Avatar
1976 CJ7
Thank for the tip on the No7 polish. Right now it is the only chrome on the Jeep so it should looks its best.
