Pilot bearing removal - JeepForum.com
post #1 of 5 Old 04-07-2019, 04:26 PM Thread Starter
misterclean2
Does anybody have any tricks to removing the pilot bearing outer race (All that is left). It is being very stubborn! Thanks in advance.
misterclean2 is offline
post #2 of 5 Old 04-07-2019, 05:19 PM
HAZCAT
HAZCAT's Avatar
Are you changing the pilot bearing? If so you don't have to remove the outer race...use the grease pack trick or bread and a deep socket or dowel rod to get the bearing out. Or you can get a puller at a parts store on loan....If you are doing something else have you already removed the bearing?
'84 CJ7, 44, 14 bolt, twin stick 300, 109"whl base, 4 linked
'93 XJ Cherokee
'70 CJ6 Dauntless v6
HAZCAT is offline
post #3 of 5 Old 04-07-2019, 05:51 PM Thread Starter
misterclean2
2000 Jeep wrangler doing clutch job. I have pulled the guts out of the bearing by using a sliding hammer puller. Have not tried the grease or bread method because it seems to be stuck too bad. I don't think any puller will work now since I have rounded the back of the race too much. Considering easy out, drilling it out, or sawing it in half.
post #4 of 5 Old 04-07-2019, 09:56 PM
mukluk
mukluk's Avatar
Use a punch and hammer to bend the race inwards so you can pry it out or grab it with some vice grips.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #5 of 5 Old 04-08-2019, 12:20 AM Thread Starter
misterclean2
Thank you, I will try that.
2005 Wrangler Pilot bearing wtf mlautner03 Engines & Drivetrain 1 04-06-2019 08:15 PM
Clutch- Pilot Bearing andresatencio TJ Wrangler Technical Forum 2 11-29-2018 04:45 PM
03 4.0L auto motor swap pilot bearing and crank inserts kabowabo TJ Wrangler Technical Forum 15 07-25-2018 06:37 PM
Pilot bearing or pilot bushing? Robbiescd YJ Wrangler Technical Forum 33 05-14-2018 12:35 PM
pilot bearing removal corvairdan YJ Wrangler Technical Forum 10 01-04-2018 07:09 PM
