JeepForum.com (https://www.jeepforum.com/forum/)
-   Cheap Tricks & Fixes (https://www.jeepforum.com/forum/f46/)
-   -   Pilot bearing removal (https://www.jeepforum.com/forum/f46/pilot-bearing-removal-4351115/)
misterclean2 04-07-2019 04:26 PM
Does anybody have any tricks to removing the pilot bearing outer race (All that is left). It is being very stubborn! Thanks in advance.
HAZCAT 04-07-2019 05:19 PM
Are you changing the pilot bearing? If so you don't have to remove the outer race...use the grease pack trick or bread and a deep socket or dowel rod to get the bearing out. Or you can get a puller at a parts store on loan....If you are doing something else have you already removed the bearing?
misterclean2 04-07-2019 05:51 PM
2000 Jeep wrangler doing clutch job. I have pulled the guts out of the bearing by using a sliding hammer puller. Have not tried the grease or bread method because it seems to be stuck too bad. I don't think any puller will work now since I have rounded the back of the race too much. Considering easy out, drilling it out, or sawing it in half.
mukluk 04-07-2019 09:56 PM
Use a punch and hammer to bend the race inwards so you can pry it out or grab it with some vice grips.
misterclean2 04-08-2019 12:20 AM
Thank you, I will try that.
The time now is 06:31 AM.
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
