Grill insert - JeepForum.com
post #1 of 5 Old 04-12-2021, 07:01 AM Thread Starter
Swamphound70
Swamphound70's Avatar
2014 JK Wrangler
Grill insert
Change my grill to a gladiator grill on a JKU. My insert does not cover the gladiator openings. Do inserts come in different lengths? Or is there trick to cover the last holes on each end?
Swamphound70 is offline
post #2 of 5 Old 04-12-2021, 12:58 PM
cranbiz
cranbiz's Avatar
Most inserts are made for the stock Jeep 7 slot grille. If your kit didn't have enough pieces, it sounds like it was not the right kit.
You might have to figure out how to make a DYI piece.
02 WJ Laredo, heavily optioned but stock
12 JK, 3.5" Teraflex/Franken lift, Bilstein 5100's, BFG KM3's 37x12.5/R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #3 of 5 Old 04-13-2021, 09:29 AM Thread Starter
Swamphound70
2014 JK Wrangler
My insert is a one piece mesh. Not pieces, I found one listed for a gladiator that is 1.25 in longer hoping that works if not then I will fabricate. Thanks
post #4 of 5 Old 04-14-2021, 07:47 AM
cranbiz
cranbiz's Avatar
I suspect you will need to fabricate one. The grille you have is wider than a stock Jeep grille in the front opening. To me, it looks like that opening is wider than the 1.25" of extra material you are getting.
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #5 of 5 Old 04-14-2021, 09:42 AM Thread Starter
Swamphound70
2014 JK Wrangler
I’m thinking the same thing. I may end up cutting some off the second insert, or put a piece of black painted sheet metal to close it off.
