Fuel Smell - JeepForum.com
post #1 of 7 Old 09-02-2019, 06:40 PM Thread Starter
MrHound
MrHound's Avatar
Fuel Smell
My 2015 Rubicon Unlimited has a fuel smell outside of the vehicle but no visible sign of leaking and we have not driven it for a few days now (since the smell started) but the smell has not gone away. The day it started I had done some work on the battery. Any ideas on what it may be or how to fix? Also, is it safe to drive to mechanic?
MrHound is offline
post #2 of 7 Old 09-03-2019, 01:00 PM
cranbiz
cranbiz's Avatar
No signs of a leak? Any codes?
02 WJ Laredo, heavily optioned but stock
12 JK, 3.5" Teraflex/Franken lift, Bilstein 5100's, BFG KM3's 37x12.5/R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #3 of 7 Old 09-04-2019, 09:50 AM Thread Starter
MrHound
MrHound's Avatar
No, I went ahead and took it in at day 6. Turns out it was a cracked housing for the fuel pump. No idea how that could have happened. Will speak to the mechanic later today. Any thoughts on how a mostly on-road jeep would get a cracked housing for fuel pump? If i get new/helpful info from mechanic, I will pass along.
MrHound is offline
post #4 of 7 Old 09-10-2019, 09:03 AM
cranbiz
cranbiz's Avatar
It may have been overtorqued at the factory and it had a stress crack. The vibrations from day to day operations could have put enough stress on it to cause the crack to expand.
I'm guessing here but it's certainly a possibility.
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #5 of 7 Old 09-10-2019, 10:36 AM
jtec
jtec's Avatar
2014 JK Wrangler
fuel fumes, a cracked fuel (EVAP) component - and you did NOT have a CEL on?
If that was not addressed - check to see if the CEL comes on for @3 seconds at every start.
jtec is offline
post #6 of 7 Old 09-16-2019, 02:49 PM Thread Starter
MrHound
MrHound's Avatar
Great feedback, thank you. The over torquing makes sense. Interesting, the CEL light did Not come on before fixing the housing; however, now it does and started immediately after. I ran my FIXD app on it and it says there is an Evap leak. The weird thing is that it was not on before I had the housing fixed. As a side note- I love that FIXD gadget. The same device I use across multiple cars and it is easy and free once you buy the device.
MrHound is offline
post #7 of 7 Old 01-12-2020, 01:47 AM
Arty McGeep
Arty McGeep's Avatar
I’ve seen the top housings on fuel pumps get dry and crack on Hondas & Toyotas near the pressure hose connector. It doesn’t cause an evap leak, just fuel. Honda actually had a recall for this on the odyssey. I’d bet that the new fuel pump rubber seal isn’t in correctly, and that’s why you get the code now. Can’t say for sure, but it’s easy to mess it up when you’re installing if you’re not careful.
Arty McGeep is offline
