ORI struts from CCOR - JeepForum.com
post #1 of 27 Old 01-24-2018, 12:09 PM Thread Starter
CCOR
Vendor
ORI STX Struts at CCOR.
Available in 8", 10", 12", 14", 16", 18", 20"
If you haven't heard about ORI Struts yet...
Made in the USA, the struts' innovative design features dual pressurized chambers and internal bypass design allowing stability as well as comfort on road or off road! They aren't just for buggies and they can make your built JK ride like a Cadillac!
Give us a call to order, or if you are local to Athens, GA, we can install a full set up for you!
706-559-9609
Some of the features of the ORI STX strut include:
  • Dual-pressurized chambers that provide for unmatched body roll stability in fast turns and on off-camber side hills. Set them to mid-stroke ride height and you can still control body roll without pushing off.
  • Specially designed compression damping valve that rushes oil back into the main cylinder 60 percent faster
  • 3-stage, velocity-sensitive compression damping that changes your soft ride to firm compression damping as the speed of the piston shaft increases.
  • Adjustable nitrogen gas pressures make the struts tunable, so you can choose a firm ride or loose articulation.
  • 2-inch piston
  • Compact design fits into tight spaces and makes many additional pieces of hardware unnecessary.
Velocity-sensitive, 7-position externally adjustable rebound damping.[/LIST]
  • Internal hydraulic bump stop on compression stroke.
  • Hydraulic end-of-stroke cushioning at full extension.
  • Cooling fins to dissipate heat and boost performance.
  • Lightweight, high-strength construction, featuring billet 6061 aluminum, stainless, and carbon steel.
  • Hard chrome steel cylinder and a tough 1-inch piston shaft.
  • Teflon-lined spherical bearings for -inch and 5/8-inch mounting bolts.
  • High-pressure 5,000-psi seals for extreme off-road use.
  • Operating temperature range from -65 F to +285 F (-54 C to +140 C).
  • Corrosion-resistant anodize outer coatings, ensuring years of performance.
Call, PM, or Post up for pricing.
Classic City Off Road (CCOR)
Email:
Shop: (706-559-9609)
CCOR is offline
post #2 of 27 Old 01-31-2018, 07:52 AM Thread Starter
CCOR
Vendor
Call, post, pm, or stop by the shop for pricing!
(706) 559-9609, Mon-Fri, 8a-5p (EST).
Email:
CCOR is offline
post #3 of 27 Old 02-01-2018, 06:04 AM Thread Starter
CCOR
Vendor
Email:
CCOR is offline
post #4 of 27 Old 05-17-2018, 02:16 PM Thread Starter
CCOR
Vendor
ORI STX 8", 10", 12", 14", 16", 18", 20" Struts now at CCOR!!
Give us a call at CCOR to order today!
706-559-9609
Thanks
CCOR
Email:
CCOR is offline
post #5 of 27 Old 06-14-2018, 06:39 AM Thread Starter
CCOR
Vendor
706-559-9609
Email:
CCOR is offline
post #6 of 27 Old 06-28-2018, 06:18 AM Thread Starter
CCOR
Vendor
706-559-9609
Email:
CCOR is offline
post #7 of 27 Old 12-07-2018, 06:22 PM
VecoPlan
VecoPlan's Avatar
I’ll be putting mine on soon. Can’t wait.
I Peter 3:15 ... are you ready?
VecoPlan is offline
post #8 of 27 Old 12-10-2018, 07:13 AM Thread Starter
CCOR
Vendor
Let us see some pics of your rig once you've got them installed!
Thanks,
CCOR
706-559-9609
Email:
CCOR is offline
post #9 of 27 Old 06-12-2019, 09:04 AM Thread Starter
CCOR
Vendor
ORI and CCOR, a great combination!!
Call and get your order in today....
706-559-9609
Email:
CCOR is offline
post #10 of 27 Old 09-23-2019, 05:47 AM Thread Starter
CCOR
Vendor
Check us out for great pricing on all your ORI needs!!
PM, Post or give us a shout @ 706-559-9609
Email:
CCOR is offline
post #11 of 27 Old 03-09-2020, 07:29 AM Thread Starter
CCOR
Vendor
706-559-9609
Email:
CCOR is offline
post #12 of 27 Old 04-24-2020, 06:30 AM Thread Starter
CCOR
Vendor
706-559-9609
Email:
CCOR is offline
post #13 of 27 Old 06-16-2020, 06:22 AM Thread Starter
CCOR
Vendor
ORI and CCOR have you covered for all your Strut needs.
A fully rebuildable system and one of the best in the business.
ORI is all you need!
PM, Post or give us a call @ 706-559-9609
Email:
CCOR is offline
post #14 of 27 Old 08-20-2020, 06:37 AM Thread Starter
CCOR
Vendor
ORI has differnt sizes available and they even have some color options.
Email:
CCOR is offline
post #15 of 27 Old 10-15-2020, 07:01 AM Thread Starter
CCOR
Vendor
ORI struts are American made.
Fully rebuildable and serviceable for a long life time of use.
So pm, post or give us a shout @ 706-559-9609 for a quote today.
Email:
CCOR is offline
You may not post new threads
