2 New Jeep JL 3" systems for the 2 door! - JeepForum.com
post #1 of 1 Old 02-25-2020, 10:50 AM Thread Starter
Rancho_Lifts
Vendor
Rancho_Lifts's Avatar
TL/DR
2 door JL systems available now!
The coils are tuned for a 2 door! No reusing a 4 door coil.
Paired with the RS5000X or the RS9000XL for the ride you want.
Experience the versatile, purpose-built Rancho® 3.0-inch* Sport suspension system for the Jeep Wrangler JL 2 Door. This new, 100-percent bolt-on system from Rancho Performance Suspension and Shocks allows for the use of up to 35-inch tires for capable, all-around performance. The Sport system also features a NEW Rancho exclusive innovation to the Jeep JL: Rancho® RS5000X or RS9000XL shocks with brand-new Dynamic Rebound Spring (DRS) technology. New DRS technology is a unique internal system that includes a precisely tuned metal spring and fortified interior construction to provide additional control, reduce body roll and prevent rod overextension inside the shock. The new system includes a pair of front and rear corner-specific progressive rate coil springs, specifically tuned to provide superior on-road comfort and off-road performance. The corner-specific springs tuned to your 2 door ensure your JL 2 Door maintains a perfectly level stance and ride – even during towing or heavy loading*.
To maintain travel integrity, the Sport system includes front bump stop extensions. Adding lift and extended travel, the system also includes front and rear extended sway bar end links, and an e-brake line relocation bracket. This system is precision engineered to be 100-percent compatible with the Jeep Factory Electronic Stability System. Designed with 35-inch tires. Kit also allows the reuse of OE wheels and tires. Backed by a Limited Lifetime Warranty.
Rancho_Lifts is offline
2 door , jeep jl , rancho , rancho rs5000x , rs9000xl
You may not post new threads
