New to the Jeep life 4x4 questions - JeepForum.com
post #1 of 17 Old 11-15-2015, 11:17 AM Thread Starter
hhipster35ca
2015 KL Cherokee
Hi everyone, we just bought a 2015 Cherokee 4x4 Sport model, automatic transmission.
It came equipped with the "active drive one" 4x4 system.
now the questions:
1. Can we shift on the fly to the different modes? or do we have to put it in neutral make the switch and then back into drive?
2. Is snow mode similar to 4-wheel low? (we get a lot of snow up here in Canada)
3. is there a speed restriction on any of the "modes" in 4-wheel drive.
Thanks for the help it is greatly appreciated.
hhipster35ca is offline
post #2 of 17 Old 11-15-2015, 12:39 PM
DuncsJeeps
DuncsJeeps's Avatar
2006 XK Commander
You can shift on the fly to all the different modes "on the fly" with AD-1 since there is no Low range.
Snow mode isn't even close to 4-Low. Changes the traction control settings, power distribution, and shift points. (See FAQ for more information.)
There are no speed restrictions for any of the modes since you don't have a Low range. There is a link to a video that explains how your 4x4 system works at the top of the forum if you're interested
Welcome to JF!
2017 WK2 Trailhawk - 3.6L: Daily Driver
: OME HD, RRO UCA, T/A KO2, Rack w/LED, Custom storage drawers, Winch, Front and Rear Bumpers - In Progress
: Sold
- RRO Sliders, 27 MPG: Sold
DuncsJeeps is offline
post #3 of 17 Old 11-15-2015, 10:38 PM
UTAH
UTAH's Avatar
One of the reasons I bought a Cherokee was for my wife - who hates to have to mess with settings. She can leave it in "auto" and it will do just fine in the vast majority of conditions.
Bill
'97 Land Rover D90
'03 TJ Rubicon
'14 JK-8 Freedom Edition
'14 KL Cherokee Trailhawk
UTAH is offline
post #4 of 17 Old 11-16-2015, 04:33 AM Thread Starter
hhipster35ca
2015 KL Cherokee
Thanks for all the input I really appreciate it!
post #5 of 17 Old 11-16-2015, 09:49 AM
JeepCACares
now the questions:
hhipster35ca,
Congratulations on your new Jeep Cherokee! Your owner's manual has additional information regarding the 4x4 operation of your Jeep. You can access a pdf. version of your manual here: http://www.fcacanada.ca/owners/en/se...php?brand=jeep
As per the owner's manual:
Snow ó
Tuning set for additional stability in inclement weather. Use on and off road on loose traction surfaces such as snow. When in SNOW mode (depending
on certain operating conditions), the transmission may use second gear (rather than first gear) during launches, to minimize wheel slippage.
When to Use 4WD LOW Range:
When off-road driving, shift to 4WD LOW for additional traction and control on slippery or difficult terrain, ascending or descending steep hills, and to increase low-speed pulling power (refer to ďAll Wheel Drive and
Four-Wheel Drive OperationĒ in this section for further details). This range should be limited to extreme situations such as deep snow, mud, or sand where additional low speed pulling power is needed. Vehicle speeds in
excess of 25 mph (40 km/h) should be avoided when in 4WD LOW range.
Our website also has a breakdown of the 4x4 systems at http://www.jeep.ca/en/4x4basics/systemwork
Top Care Specialist
FCA Canada
JeepCACares is offline
post #6 of 17 Old 11-17-2015, 04:22 PM Thread Starter
hhipster35ca
2015 KL Cherokee
JeepCACares
Thanks for all the info, but one question comes to mind when reading your reply:
Snow mode is considered low range? because we don't have any setting that actually says "4WD Low"
thanks
post #7 of 17 Old 11-17-2015, 05:37 PM
DuncsJeeps
DuncsJeeps's Avatar
2006 XK Commander
JeepCACares
thanks
The 4WD system on your Jeep is Active Drive 1.
Active Drive 1 does not have 4WD Low. Active Drive 2 and Active Drive Lock are the two 4WD systems on the KL that have 4WD Low.
Snow mode is amazing in the snow, and can be used at any speed, and shifted into at any speed.
: Sold
post #8 of 17 Old 11-18-2015, 10:41 AM
JeepCACares
JeepCACares
thanks
hhipster35ca,
Sorry for any confusion. SNOW is not the same as 4WD Low.
The detail associated with 4WD Low in my post pertains to vehicles equipped with that function. Setting to Snow mode will adjust the system for greater traction in certain inclement conditions.
Top Care Specialist
FCA Canada
post #9 of 17 Old 11-18-2015, 02:40 PM
remmons
remmons's Avatar
2015 KL Cherokee
Welcome to the forum! I've been on here for a few years now with a few different Jeep models, and no matter which section you're in you will always get friendly knowledgeable people who will readily and freely answer any of your questions and/or concerns.
I've just picked up a '15 Trailhawk V6 model a week ago and it has been a dream to drive. IF you had the Active Drive II or the Trailhawks Active Drive Lock system and wanted to shift into low range, then yes, you would have to be sitting or going under 3-5 mph in neutral to shift into low range. But since you only have the Active Drive I version, you don't have to stop to shift it in and out of Snow mode. If you can, read up on the above links to further understand how the various 4WD systems work.
remmons is offline
post #10 of 17 Old 11-18-2015, 03:41 PM Thread Starter
hhipster35ca
2015 KL Cherokee
Thanks once again for the help!!!
post #11 of 17 Old 11-20-2015, 01:09 PM
mmahamm
2015 KL Cherokee
Originally Posted by remmons View Post
...IF you had the Active Drive II or the Trailhawks Active Drive Lock system and wanted to shift into low range, then yes, you would have to be sitting or going under 3-5 mph in neutral to shift into low range. But since you only have the Active Drive I version, you don't have to stop to shift it in and out of Snow mode...
Even with Active Drive II or Active Drive Lock, you can shift to SNOW mode --or sport mode--on the fly.
mmahamm is offline
post #12 of 17 Old 11-20-2015, 01:23 PM
remmons
remmons's Avatar
2015 KL Cherokee
Re-read my post. I'm sure that I had covered that. If not, I'll clarify.
remmons is offline
post #13 of 17 Old 11-20-2015, 01:49 PM
DuncsJeeps
DuncsJeeps's Avatar
2006 XK Commander
If you didn't, I know I did!
: Sold
post #14 of 17 Old 11-20-2015, 02:01 PM
remmons
remmons's Avatar
2015 KL Cherokee
Lol, yep. I can see now how it can be confusing. Typing in the cold can do strange things to the mind.
remmons is offline
post #15 of 17 Old 11-20-2015, 09:08 PM
18Fox20
In most cases you wouldn't really want 4-low in the snow. Also, top gear is limited in snow mode. 6 or 7. Can't remember which.
18Fox20 is offline
