Max tire size? - JeepForum.com
 4Likes
post #1 of 16 Old 05-14-2017, 09:49 AM Thread Starter
cotton16
2016 KL Cherokee
Max tire size?
Ok folks I see in other forums they have a Max tire size thread. I would like to know what has been done, preferably with photo evidence. I have read 265/65r17 that seems like a big jump. But if I can clear them with no lift I will be going that route sooner than later. Just want to see some one else with it done. Here is Heihei.
Sent from my SM-G955U using Tapatalk
cotton16 is offline
post #2 of 16 Old 05-14-2017, 03:36 PM
SeaComms
SeaComms's Avatar
Yes in a nutshell.
I ran 245/70 for a while before a lift and they fit fine. The outer edge of the tyre just rub the back plastic liner of the front wheel well on full lock when brand new, but that plastic can move a good half inch so no probs at all. The 265/65 are the same diameter and fit just as well as long as you don't run wheel spacers.
You can not run larger than that without a lift as they may hit the lower front spring perch.
This is mine with the 245/ 70 Goodyear Duratracs LT version.
Sent from my SM-G930F using Tapatalk
cotton16 likes this.
Cheers, Dave.
2015 Granite Pearl Trailhawk 3.2L V6 with Aussie Lift and 245/70 R17 Duratracs
SeaComms is offline
post #3 of 16 Old 05-14-2017, 06:56 PM
richallcorn
Keep in mind that with the new tech in the Trailhawk (Cherokee) there is no provision for adjusting the odometer if you change the tire size. Unless that has recently changed, that's the latest word I get on my 2017.
Sent from my iPhone using Tapatalk Pro
richallcorn is offline
post #4 of 16 Old 05-14-2017, 07:03 PM
SeaComms
SeaComms's Avatar
No it hasn't changed.
However going from the 245/65 to 245/70 (or 265/65) is an increase if approx 3.5% (from memory). Mine read approx 3% below actual speed with stock tyres so now reads around 0.5% higher. In real terms this means at 100kmh on the speedo my GPS speed is still showing 100kmh. At 110kmh my GPS speed is showing 111kmh.
So to be honest I am not worries at all by the inability to correct the speedo/odometer.
cotton16 and richallcorn like this.
Cheers, Dave.
SeaComms is offline
post #5 of 16 Old 05-14-2017, 09:00 PM Thread Starter
cotton16
2016 KL Cherokee
Speedo doesn't bother me. Gonna get a set of 265/65r17 grabber ats soon(while my stock tires are worth reselling). Thanks folks.
cotton16 is offline
post #6 of 16 Old 05-18-2017, 06:03 PM Thread Starter
cotton16
2016 KL Cherokee
They are on and good to go. Very very mi no or rubbing even through all of this. https://youtu.be/9mBA0SW6dh8
cotton16 is offline
post #7 of 16 Old 05-31-2017, 05:13 PM Thread Starter
cotton16
2016 KL Cherokee
Still running then and don't just fine.
https://youtu.be/PJASCE-vPSs
cotton16 is offline
post #8 of 16 Old 02-11-2019, 11:07 AM
AliasDz
AliasDz's Avatar
2015 KL Cherokee
I have a 2015 KL Cherokee and wanted to get bigger tires going from the standard size of 225/65 r17 to 255/60 r17. The dealership said that if I did that, I could end up with having a internal transmission failure. Has anybody ever hear of that happening?
Thank you in advance for your comments!!
-Rick
AliasDz is offline
post #9 of 16 Old 03-05-2019, 10:27 AM
splumer
2015 KL Cherokee
My 2015 Limited has 225/60R18's, but the selection for 18" rim size tires seems very limited. (Pun intended!) How wide do you think I could go? 245? I don't want to change the diameter because of the speedo.
"I’ve had a few weird experiences and a few close brushes with total weirdness of one sort or another, but nothing that’s really freaked me out or made me feel too awful about it. "
- Jerry Garcia
splumer is offline
post #10 of 16 Old 03-06-2019, 05:36 PM
ForcedInduction
2019 KL Cherokee
The dealer may be able to adjust the speedometer by reprogramming the PCM. It depends on the available tire options.
2019 Cherokee Limited
2.0 Hurricane
ForcedInduction is offline
post #11 of 16 Old 03-07-2019, 10:42 AM
fryguy1114
2017 KL Cherokee
Sorry, but adjusting the speedometer is not possible on our Cherokees. @Tyler-98-W68 says that even when using his HP Tuner equipment, the option is there, but it doesn't work. My local speed shop checked and says none of their tuning equipment has the Cherokee in their database for tire size adjustment.
2017 Cherokee TH, Dobinsons Suspension, Hazard Sky TH Lift, RRO Step Rails
fryguy1114 is offline
post #12 of 16 Old 03-12-2019, 06:48 PM
Tyler-98-W68
2016 KL Cherokee
Correct.
There is no option in the PCM or TCM to reprogram the tire size either
2016 Trailhawk 3.2L | Player3 Tuned Via HP Tuners
Tyler-98-W68 is offline
post #13 of 16 Old 03-18-2019, 10:41 AM
coloradoman
What is the biggest tire size with a lift without rubbing off road? Can you fit 32s on these things?
coloradoman is offline
post #14 of 16 Old 03-18-2019, 04:51 PM
fryguy1114
2017 KL Cherokee
You can IF you have a lift and do the pinch seam mod. If you're up about 2.5" with lifts, you can fit some 31.6" tires with just barely a rub at full turn. That's what I'm running as I didn't want to do the pinch seam mod.
If you're interested, here's a video showing how it's done:
post #15 of 16 Old 03-19-2019, 09:36 AM
coloradoman
Thats a lot of work just to get another half inch of tire size. Too bad you can't just slap on 32s with a lift. What exactly is the size tire you have?
I am trying to get at least a front independent suspension (preferably all independent suspension) that I can put 33s on. No trucks as I want to sleep in the back on trips.
The grand cherokee wk2 seems to max out at 32s and a lift doesn't help at all.
The xterra I think can put 33s on without any mods, but the xterra powertrain is a million years old and gets terrible mpg and is rear wheel drive unless you manually switch it to 4hi. I like how these vehicles like the grand cherokee and cherokee do it automatically for you. One nice thing about the xterra is that 16 inch rims fit.
I just want a super comfy off road experience. I want lots of side wall and independent suspension to absorb all those rocks.
