Check engine light - JeepForum.com
post #1 of 6 Old 09-11-2021, 12:15 PM Thread Starter
Lexis35
Check engine light
So I took my Jeep to a Jeep dealer to get my check engine light fixed short story it came back on so I hooked it up to check what’s wrong and it says it could either be my 3 way catalyst converter in bank 1, my exhaust tube, an intake air leak or my fuel injects maybe faulty so if any one could give some advice on whether I can do these myself or I should just take it back to the dealer oh it’s also a 2014 cheeroke thanks
Lexis35 is offline
post #2 of 6 Old 09-11-2021, 12:27 PM
Wyo
Wyo's Avatar
Wrong Forum this is for the XJ not the new ones.
Post your question here and you may get an answer. >>> https://www.jeepforum.com/forum/f428/
Wyo is offline
post #3 of 6 Old 09-11-2021, 02:25 PM
Saudade
1988 XJ Cherokee
When you go there, post the actual code(s) you're getting.
Saudade is offline
post #4 of 6 Old 09-14-2021, 05:47 AM
ChrisHager
ChrisHager's Avatar
Moved.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #5 of 6 Old 09-16-2021, 07:56 PM Thread Starter
Lexis35
Thank you so much
Lexis35 is offline
post #6 of 6 Old 09-23-2021, 03:15 PM
XJ99
XJ99's Avatar
2019 KL Cherokee
Originally Posted by Lexis35 View Post
Thank you so much
You will probably get a better response over on
https://www.jeepcherokeeclub.com/forums/
Yeah, and if you have the codes that would help..
When we do right, no one remembers. When we do wrong, no one forgets.
XJ99 is offline
