Help with 2001 XJ Vacuum leak - JeepForum.com
post #1 of 6 Old 08-22-2019, 07:11 PM Thread Starter
Jborg58es
Help...looking for a leak. OBD code says small leak. Had a cowl induction that was illegal and I got a legal system, still won't smog, has a error code. Map on the firewall shows an EVAP canister with 3 hoses attached. I can not find it! Anybody know where the canister should be?
Thanks.
John
Jborg58es is offline
post #2 of 6 Old 08-23-2019, 06:36 PM
mukluk
mukluk's Avatar
Under the Jeep, left side, just forward of the rear axle.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #3 of 6 Old 08-23-2019, 11:41 PM Thread Starter
Jborg58es
thanks....never would have looked there.
post #4 of 6 Old 08-24-2019, 05:56 AM
jtec
2014 JK Wrangler
post the codes - might ring a bell and we can make suggestions from experience.
Illegal induction system - Are you in California? I never heard of anything like that
jtec is offline
post #5 of 6 Old 08-26-2019, 12:17 AM Thread Starter
Jborg58es
Yes, In California. But turned out a good thing. Got a KN system and when I pulled out the Stinger cowl induction I found NO air filter at all. God knows what's already been sucked into the engine. The codes are P0456-small leak and P0455-gross leak (no flow). I did find a crack in one of the plastic tubes coming off the purge solenoid [not the tube with the service fitting]. I cut that and patched with rubber line.
Thanks for any input.
post #6 of 6 Old 08-26-2019, 09:04 AM
jtec
2014 JK Wrangler
Wow - I am learning this california BS inspection is draconian.... Must have been written by new car dealers to drive business....
glad you got it.
jtec is offline
