New heavy duty rear track bar for the Jeep Gladiator - JeepForum.com
post #1 of 1 Old 06-02-2021, 03:02 PM Thread Starter
Rancho_Lifts
Vendor
Rancho_Lifts's Avatar
Thumbs up New heavy duty rear track bar for the Jeep Gladiator
TL/DR
Super beefy
Center that rear axle
D2 bushing for a maintenance free care.
Check with your favorite retailer on cost.
Rancho® HD Rear Adjustable Track Bar for Jeep® Gladiator JT
Designed to work on stock and up to 5-in. suspension systems, the Rancho® HD adjustable rear track bar allows you to center the rear axle in the proper position on your Jeep® Gladiator JT. The forged ends feature Rancho’s innovative high-articulation, maintenance-free D2 bushings for superior dampening plus improved ride and handling characteristics.
1. COMPATIBILITY -- Designed for stock and up to 5-in. suspension systems on your Jeep Gladiator JT
2. CENTERS AXLE -- Precise lateral adjustments allow you to center the axle to the proper position
3. RESISTS CORROSION -- Durable black powder-coat finish resists rust and corrosion
4. ENGINEERED TO LAST -- 1.25-In. OD diameter bar made of heavy-duty, 0.281-in. DOM wall tubing with forged ends for long life
5. EASY TO INSTALL -- Bolts to OE mounts for easy installation
6. MAINTENANCE-FREE BUSHINGS -- Features Rancho’s D2 high-articulation, grease-free, self-centering bushings for reduced noise, vibration and harshness and improved handling and ride quality
7. BUY WITH CONFIDENCE -- Comes with Rancho’s limited lifetime warranty
Rancho_Lifts is offline
