Duroflex Axle Side Bushing Kit... - JeepForum.com
post #1 of 2 Old 07-21-2015, 11:40 AM Thread Starter
Metalcloak
Vendor
Metalcloak's Avatar
MetalCloak's Duroflex bushings are designed to work in parallel with each other, but what about the upper control arm? What do you do on the axle side?
While factory Clevite bushings will work in conjunction with Duroflex bushings, they have a very limited range of performance.
Introducing the Duroflex Weld-On Bracket and Axle Bushing Kit for JK Wranglers...
The kit includes a press-in sleeve and bushing for the cast side and a weld on bracket and housing for the other side.
As a note, this kit is designed to ONLY work with the Metalcloak Duroflex Control Arms.
It's Your Jeep, Only Better
Metalcloak is offline
post #2 of 2 Old 01-11-2016, 09:36 PM
jon1371usmc
Can this kit be retrofited to a jeep Lj? Considering metalcloak control arms but want a way to upgrade the axle housing bushings as well
jon1371usmc is offline
