Blocked images - JeepForum.com
 1Likes
post #1 of 36 Old 02-16-2019, 11:44 AM Thread Starter
agear
Blocked images
When I view a post most images come up as blocked image. Dies anyone know how to fix it
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #2 of 36 Old 02-19-2019, 09:29 AM
PhilipB
Administrator
PhilipB's Avatar
1987 KK Liberty
Example link to a page with blocked images?
Kevin
AG Jeff likes this.
PhilipB is offline
post #3 of 36 Old 04-20-2019, 04:29 PM Thread Starter
agear
Here you go
https://www.jeepforum.com/#/topics/1231816
The first post on the page says loading image then block image
agear is offline
post #4 of 36 Old 04-22-2019, 03:18 AM Thread Starter
agear
Bump
agear is offline
post #5 of 36 Old 04-22-2019, 11:52 AM
PhilipB
Administrator
PhilipB's Avatar
1987 KK Liberty
Those images are blocked because they're hosted on HTTP.
We recently added HTTPS. That thread was created before this was added.
All in all, images hosted on sites not using HTTPS will not show on sites using HTTPS as Chrome, Firefox, Safari etc will block them as it sees them as a security risk.
The OP will need to update those images to HTTPS and PM us the new links.
Ed
PhilipB is offline
post #6 of 36 Old 04-23-2019, 02:30 PM Thread Starter
agear
Bump
agear is offline
post #7 of 36 Old 04-24-2019, 08:55 AM
PhilipB
Administrator
PhilipB's Avatar
1987 KK Liberty
Guessing you missed Ed's reply? Those images won't work here until the site the images are hosted on gets a SSL certificate
Kevin
PhilipB is offline
post #8 of 36 Old 06-11-2019, 06:35 PM
mpodell
Pictures
Why are the pictures that I click on blocked I am a registered user
mpodell is offline
post #9 of 36 Old 06-12-2019, 01:28 PM
PhilipB
Administrator
PhilipB's Avatar
1987 KK Liberty
Which thread is giving you this issue?
Link it here and we'll look into it.
Ed
PhilipB is offline
post #10 of 36 Old 07-03-2019, 05:17 PM Thread Starter
agear
I'm about as techy as s caveman. When I clicked on the blocked image it didnt show any option to update the blocked image . Any ideas .... ?
agear is offline
post #11 of 36 Old 07-04-2019, 01:35 PM
PhilipB
Administrator
PhilipB's Avatar
1987 KK Liberty
Hello there,
These are the images:
http://www.jeepforum.nl/uploads/1290...7_3_123837.jpg
http://www.jeepforum.nl/uploads/1290...77_3_63848.jpg
http://www.jeepforum.nl/uploads/1290...77_3_82803.jpg
As you can see, the images are in "http"
If they're not on "https" then the images will not show up.
This is due to a security feature that we implemented.
However, if you click on the links above, it should show you the image in another window.
Only the original poster can get this fixed by hosting the image on another site and edit the link within the post.
Ed
PhilipB is offline
post #12 of 36 Old 07-04-2019, 05:53 PM Thread Starter
agear
That's cool. Ty. But it seems like 90 percent of the images are like that
agear is offline
post #13 of 36 Old 07-05-2019, 11:55 AM
PhilipB
Administrator
PhilipB's Avatar
1987 KK Liberty
Most if not all sites are now adding HTTPS so these images will start to come back as the sites update themselves. Unfortunately, there's nothing we can do to fix them.
Niall
PhilipB is offline
post #14 of 36 Old 07-06-2019, 12:55 AM Thread Starter
agear
Okay, thanks though
agear is offline
post #15 of 36 Old 07-08-2019, 01:31 PM
Fourtrail
1974 CJ6
@Phillipb if the browser is 'blocking' images in the normal forum pages when they are not HTTPS://, then why do they show up just fine when I quote a post with a blocked image? Also if we are forced to use HTTPS:// images, then why does the inset image button still start the web address with http://?
below is a 'blocked' image that is added with the image button in a reply.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is online now
Blocked Image? Cuzzin67 WJ Grand Cherokee Forum 13 12-21-2019 06:31 PM
Various Driveshaft Yokes/Flanges superheady Drivetrain 2 01-18-2019 03:14 PM
Dana 35 diff sound / contamination problem with images Dry_Only XJ Cherokee Technical Forum 4 08-20-2018 11:14 AM
