Zj clayton/iro/rustys 4link longarm custom rig suspension questions - JeepForum.com
post #1 of 1 Old 04-12-2019, 09:36 PM Thread Starter
Mudnbloodzj97
Mudnbloodzj97's Avatar
Hey fellas new to the forum, got my jeep couple years ago have 3.5 lift on 31st stock axles, just a basic system me and my brother did now I've learned more about what I wanna do, the plan is to swap matching waggy 44s I've found from a coworker, under her with 4.11 gears.. I believe that's good for ever day and offroad use right?... but anyway tryna keep cost down and i like claytons system yes its welded i kno and what I came up with is clayton 3 piece crossmember frame clayton subrail and clayton rear control mounts. Then on rear axle for the truss was looking at iro 4link axle swap kit that comes with the four tabs for upper arms, the universal truss they have. Front axle hopefully will be artec coil bucket with mounts w sway bar tabs and the artec truss with uca mounts that have currie joints. And the Clayton arms around all together gonna run 1600 bucks but i, wondering if rustys arms will work they'll run me 1000 dollars. I'm not rolling with front 3link. I don't like it. This is pretty much what I came up with if not it's ordering a kit from Clayton for 3k that has everything or carid for 2100 and that's just control arm and mount system. Any info on this or the type of build I'm going for would be appreciated bros. Thanks also.. in the rear with the 4link set up do u need track and sway bar...?
send it shane!
Mudnbloodzj97 is offline
The Johnny 5 Build -Syntax- Jeep Builds 51 03-08-2019 10:25 AM
New Tire and Suspension Strategy Questions T1m WK Grand Cherokee & XK Commander Forum 3 01-13-2019 08:15 AM
WJ hunting rig was thoughts and questions Bigdawg90 WJ Grand Cherokee Forum 9 09-19-2018 06:30 PM
Superlift, Coilovers, Suspension questions nyd WK Grand Cherokee & XK Commander Forum 1 03-13-2018 10:17 AM
Suspension Questions; 2014 GC Limited cag2014 WK2 Grand Cherokee Forum 3 02-19-2018 09:49 AM
