YJ bumper build question - JeepForum.com
post #1 of 12 Old 11-07-2018, 09:41 PM Thread Starter
Robort
Robort's Avatar
I'm building bumpers for my YJ and need some advice. I'm using A 60 inch piece of 3/16 42 tubing and 3/16 angle iron for top frame mounts with 3/16 2 flat bar for the bottom mount. I made recovery tabs out of 3/4 x 3.5 with a 1 inch hole steel which I want to have welded by a pro (welder friend) onto the face of the bumper. Does that sound ok. I got a couple of pictures before I weld it together
20181105_185439_1541648406976.jpg   20181107_192128_1541648439778.jpg   20181107_192142_1541648471011.jpg
Robort is offline
post #2 of 12 Old 11-08-2018, 12:40 PM
06JeepLJ
2014 JK Wrangler
when i build mine, i slotted the tube clear through and made the tabs long enough to come out the back to add more weld area... if you think about the weight of a stuck jeep and the amount of force... i tend to go overkill though...
Chad,
I'm hittin Easy Street on MUD TIRES!!!
06JeepLJ is offline
post #3 of 12 Old 11-08-2018, 01:13 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
I fine with my old school tow hooks on top. Those big bosses are fine for towing the Jeep behind a motor home or something, but I feel are overkill for a simple extraction nudge via strap. If I'm really stuck, my winch is used rather than a hard strap pull. While I'm giving you a hard time... Simply fabbing up a simple bar bumper seems way under imagined. Design something that wraps around the frame, not just a minimal bolt on.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #4 of 12 Old 11-08-2018, 05:44 PM Thread Starter
Robort
Robort's Avatar
Originally Posted by JeeperDon View Post
I fine with my old school tow hooks on top. Those big bosses are fine for towing the Jeep behind a motor home or something, but I feel are overkill for a simple extraction nudge via strap. If I'm really stuck, my winch is used rather than a hard strap pull. While I'm giving you a hard time...[IMG class=inlineimg]/forum/images/JeepForum_2016/smilies/tango_face_devil.png[/IMG] Simply fabbing up a simple bar bumper seems way under imagined. Design something that wraps around the frame, not just a minimal bolt on.
Ok Ill paint some unicorns on it. But is it strong enough if I have to go through with the recovery blocks i need more steel bar. I just want it strong enough not to break. Show me a picture of "wraps around the frame"
Robort is offline
post #5 of 12 Old 11-09-2018, 08:34 AM
JeeperDon
JeeperDon's Avatar
I know you're well into your project, and it will end up fine. Since you asked though, I made this one a couple years ago. The unpainted photo shows the 1/4" steel 'box' that slips over the bumper, making the Jeep only 1/4" longer compared to no bumper. The only design points were, minimal rock climbing interference, tires as exposed as possible, protect the fenders, and hold the winch and hooks. The whole thing is held on with six grade 8 bolts, four for the hooks and two underneath below the hooks.
Web Admin for
post #6 of 12 Old 11-11-2018, 11:18 PM Thread Starter
Robort
Robort's Avatar
This is how it looks so far im going to angle the ends up
Robort is offline
post #7 of 12 Old 11-13-2018, 04:11 PM Thread Starter
Robort
Robort's Avatar
finished the ends now i need to decide on a winch guard
Robort is offline
post #8 of 12 Old 11-13-2018, 10:09 PM Thread Starter
Robort
Robort's Avatar
I decided to go a little smaller and put the first coat of paint on it
Robort is offline
post #9 of 12 Old 11-14-2018, 10:06 PM Thread Starter
Robort
Robort's Avatar
All done
Robort is offline
post #10 of 12 Old 08-01-2019, 03:56 PM
strykersd
Looks good! I did the same for my 3/16" bumpers and after running the numbers of the weight of my jeep there was no notable advantage to extending the recovery points through the bumper to the frame. The 3//16" wall tubing will be plenty strong to pull your jeep in any direction if it's welded right.
strykersd is offline
post #11 of 12 Old 12-05-2019, 12:11 AM
trask_unit_jeep
Did you end up making slots for your shackle mounts or just welding them to the face? Im building a front stubby bumper right now.
trask_unit_jeep is offline
post #12 of 12 Old 12-05-2019, 02:43 PM Thread Starter
Robort
Robort's Avatar
I welded them to the face
Robort is offline
