Winches - JeepForum.com
post #1 of 50 Old 04-26-2011, 11:33 PM Thread Starter
Jason_alex
Winches
Why dont people on here build winches...
not just the cheep o direct pull winches that use 5 hp but the worm driven winches that can pull 11,000 lbs with a 3/4 hp motor?
2001 Jeep Grand Cherokee Laredo 4.0L Selec-Trac 2.5" ROR lift
1977 Trans Am 400 bored 40 over new paint new sub-frame.
Jason_alex is offline
post #2 of 50 Old 04-27-2011, 04:35 AM
Netpackrat
Because it's hard.
Netpackrat is offline
post #3 of 50 Old 04-27-2011, 07:10 AM Thread Starter
Jason_alex
It shouldn't be that hard you can buy a DC motor that hooks right into a worm gear box and then do a sprocket reduction on the backside with a chain yes sure you would have to make a tail stock and figure you sprocket reduction and make a frame, none of witch is to hard. I made and pored all the castings for my winch and pored some of my gears and cut them myself.
instead of a normal motor i just converted a old ford starter into the motor its only like 3/4 horse but pull like an ox. and im drawling a fraction of the amps of the 5 hp direct drive motors are.
post #4 of 50 Old 04-27-2011, 07:46 AM
CJ7Pilot
CJ7Pilot's Avatar
1982 CJ8
Okay, so let's see some pics of the one you made....
Now I must hurry on... for there they go, and I am their leader...!
CJ7Pilot is offline
post #5 of 50 Old 04-27-2011, 08:09 AM Thread Starter
Jason_alex
Here we go then
On the picture of the motor i drilled a second post through the motor replaced and rewired to coils so i can have a bi-directional motor.
The 2nd pictures just bolts directly up to the 3rd or 4th picture over the main gear that i cut that is connected to the drum
Setting at 350:1 gear reduction over all
post #6 of 50 Old 04-27-2011, 09:41 AM
hallway94yj
What would it cost to make me one??
hallway94yj is offline
post #7 of 50 Old 04-27-2011, 10:04 AM Thread Starter
Jason_alex
that's why i brought it to the fab form, just wondering why no one makes these? or if anyone has?
post #8 of 50 Old 04-27-2011, 10:06 AM
theducksguts
theducksguts's Avatar
I was wondering where this was going. Any video of it pulling?
Check out my
theducksguts is offline
post #9 of 50 Old 04-27-2011, 10:08 AM Thread Starter
Jason_alex
not yet... i will get a video of it pulling... i was going to use 5/16ths galvanized aircraft cable, anyone have any other thoughts for it? acording to my calculations i should be able to pull the 5/16ths in half what else could i use that might be stronger?
Breaking strength from 9,800 to 12,500
How dose synthetic rope stack up to that?
post #10 of 50 Old 04-27-2011, 10:19 AM
Machinist
depends on the size rope you get.Where did you get the housing from?I can machine all that good stuff so this may turn into a possibility.
Machinist is offline
post #11 of 50 Old 04-27-2011, 10:31 AM Thread Starter
Jason_alex
casted it my self
post #12 of 50 Old 04-27-2011, 10:58 AM
Kettles
Kettles's Avatar
You say that like we all have a foundry and a machine shop in our basements, lol.
Regardless though, its pretty neat that you made one yourself.
AS far as synthetic rope, the same diameter synthetic winch lines can have more than double that capacity.
http://www.masterpull.com/cpage.cfm?cpid=197
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline
post #13 of 50 Old 04-27-2011, 11:14 AM
SFT2
SFT2's Avatar
Isn't the worm gear going to make it a bit slow compared to a planetary gearbox? Like, wait for the seasons to change slow?
Mine- 2k TJ, RC 2.5 lift, .75 spacers, Soft 8s, 33" KM2s, winch, lights, and so on
Hers- 06 WK, bone stock until she leaves it and the credit card with me for an unsupervised weekend
You're the retarded offspring of five monkeys having butt sex with a fish-squirrel.
SFT2 is offline
post #14 of 50 Old 04-27-2011, 01:00 PM Thread Starter
Jason_alex
Worm gear makes it probably twice as long as but has a lot more power and can hold a load in the middle of the pull such as upward 6,000 lbs in the air with no power and it wont let the load drop down. Instead of having a 5hp motor drawing who know how many amps you can drop down to a 3/4 hp motor and have more pull than a planetary gearbox.
post #15 of 50 Old 04-27-2011, 01:03 PM Thread Starter
Jason_alex
Well since it is the fab forum who know, but you can buy the gearbox and motor from automation direct and make a sprocket reduce it more using chain. and all you would have to do is make a drum and frame.
Which one of these winches? stokesj19 General Jeep & Off-Road Equipment 4 04-25-2011 09:56 PM
To those with winches... sbulla General Jeep & Off-Road Equipment 48 03-11-2008 02:16 PM
Winches XabuJr General Jeep & Off-Road Equipment 11 05-17-2006 06:06 AM
winches vermontjeep General Jeep & Off-Road Equipment 2 03-25-2005 06:03 PM
winches lsufanjeeper General Jeep & Off-Road Equipment 8 03-04-2005 09:12 AM
