Welders read this!! It could save your life!! - Page 5 - JeepForum.com
 1Likes
post #61 of 66 Old 10-26-2016, 01:44 PM
pgk1
Wow! Scary stuff there, I'll think twice next time I grab any old solvent off the shelf before welding something. I have used Acetone to clean for years because it dries so fast I always figured I was good to go, I'll have to check into that to see how safe that is..
pgk1 is offline
post #62 of 66 Old 10-29-2016, 07:00 AM
thecleaner
thecleaner's Avatar
The biggest concern you'll have with acetone is its flammability. As long as you're accounting for that (good ventilation), you should be fine.
It's specifically the perchloroethylene in the presence of an arc weld that is the concern. Stuff doesn't burn, but converts into the gas used to kill more people than any other chemical weapon in WW1
pgk1 likes this.
You'll be amazed at how much government you'll never miss - Mitch Daniels
thecleaner is offline
post #63 of 66 Old 01-01-2017, 07:52 PM
Bingobiker
Wish I had known about this when it was first posted. I'm sure I have used brake and contact cleaners in the past with no adverse effects,"Won't be doing that again".
Thanks for the post, it's not to late to teach this old dog new tricks...
Bingobiker is offline
post #64 of 66 Old 06-19-2021, 07:30 AM
77KW
77KW's Avatar
I've done the same. Thanks for the info.
77KW is offline
post #65 of 66 Old 09-27-2021, 09:19 PM
thisoldjeep
Silly me, I've only ever used Brake Kleen for brakes. Have used a lot of Purple Power though.
thisoldjeep is offline
post #66 of 66 Old 10-11-2021, 01:56 PM
nagzpl12
Yes it is very helpful
nagzpl12 is offline
Arc Welding - thinner rod or stitch welding attachment? rugsucka Fabrication Shop 17 12-20-2012 08:17 PM
First welding projects: welding cart and rock sliders johnsoninc86 Fabrication Shop 13 12-11-2011 11:48 PM
brake cleaner problem (welding) attackcammel Fabrication Shop 31 10-12-2011 01:43 PM
engine cleaner / valvetrain cleaner? BNovak Engines & Drivetrain 8 02-14-2007 05:44 PM
Welding - full penetration vs. welding both sides Matt in TN Fabrication Shop 11 01-21-2006 07:03 PM
