PVC pipe bumper? - JeepForum.com
post #1 of 33 Old 08-07-2008, 11:17 AM Thread Starter
winkosmosis
winkosmosis's Avatar
PVC pipe bumper?
I was trying to think of ways to create a bumper that absorbs energy and is easy and cheap to replace. What about a bumper made of, say, 6" PVC pipe? You could use a straight steel pipe as a backing to bolt to the vehicle frame, then overlay it with foam, then cut out a section of the PVC and overlay it on the steel tube.
You could gain ground clearance over a stock bumper, and when you drag it over a rock or something, it will deform but won't dent. If it breaks, take a trip to Home Depot and spend a few bucks for a new bumper. You can't use it for recovery, but that is what hooks are for.
And if you get in an accident, it will absorb some energy, unlike a rigid steel bumper. Easier on your vehicle and the one that you crash into/ crashes into you.
What do you guys think?? Is it feasible?
Atheist Jeep Club member #3
Non-Astrologist Jeep Club member #?
Pull the Socialist Plug on Old People Jeep Club member #1
winkosmosis is offline
post #2 of 33 Old 08-07-2008, 12:03 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Lawsuit waitin to happen after an accident.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #3 of 33 Old 08-07-2008, 12:10 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
PVC will crush and explode under the impact you'd see in a crash. There would be shrapnel of plastic flying everywhere, probably going fast enough to break windows and/or become lodged in someone's flesh, put eyes out, etc.
actually steel is going to absorb energy A LOT better than PVC pipe would. The forces involved in an accident are tremendous... Force = Mass * Acceleration. Use 1/8th wall or 1/16th wall bumpers, they are much thinner than the frame and will bend under force. Thats why the stock bumper is so thin... Fill it with expanding foam insulation if you like. Its all about Elastic Modulus and Young's Modulus.
try steel bumpers with rubber stock absorbers on them, like delivery trucks have:
http://www.mcmaster.com/ctlg/DisplCt...av&ToolsetAct=
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #4 of 33 Old 08-07-2008, 12:45 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
You could also line the front of the bumper with thick rubber. That would help for the slow speed "fender benders". You might want to browse around on Mcmaster Carr's site.. they have all sorts of plastic/rubber stuff.
Basically, if it's "cheap" and "effective", the manufacturers would've been doing it already.
BESRK is offline
post #5 of 33 Old 08-07-2008, 02:20 PM Thread Starter
winkosmosis
The rubber pads are a good idea. Low profile bumper + thick rubber = win?
The steel bumpers though.. I've seen pictures posted after accidents, and people are proud of the bumper not taking damage. Then one guy posted a month later saying his frame cracked. It was after a Mustang hit him at 50mph but it looked like his XJ had no damage.
Which bumpers are thin enough to deform and absorb energy?
post #6 of 33 Old 08-07-2008, 02:57 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
The stock ones...
BESRK is offline
post #7 of 33 Old 08-07-2008, 03:36 PM
Unlimited04
this is what the stock bumpers are designed to do. notice the fronts have rubber bumpers, and the rears have a "crush zone" on a TJ. On XJ's they have "impact quality foam" front and rear with a plastic sleeve, just like almost every other vehicle made since the mid 80s.
Useful Write-Ups:
Funny:
post #8 of 33 Old 08-07-2008, 03:44 PM Thread Starter
winkosmosis
I meant aftermarket steel bumpers.
How much energy can the stockers actually absorb though? They aren't required by federal regulation to absorb anything, because the XJ is classed as a light truck right?
post #9 of 33 Old 08-07-2008, 04:46 PM
Unlimited04
no. all bumpers on vehicles in the US are required to survive a 5mph impact into a concrete wall with no damage (aside from a scratched finish).
pretty much the entire point to aftermarket bumpers is beefing up the front or rear end for off-roading, they don't care about crash testing. however, some are crash tested to work with airbags, and the ARB front bumpers are only ones that are that I know of. think about it - hitting a tree, rock or resting on your bumper in a breakover angle situation would destroy a stock setup, or any setup ment to collapse, but beefy bumpers are designed to armor the vehicle from damage.
Useful Write-Ups:
Funny:
post #10 of 33 Old 08-07-2008, 05:05 PM Thread Starter
winkosmosis
No, all vehicles aren't required to have 5mph bumpers. The regulation only applied to passenger cars, and they were required to hit an immovable object at 2.5mph. They consider that equivalent to hitting a parked moveable car at 5mph. NOW the regulation is 2.5mph, not 5mph. So that means hitting an immovable object at 1.25mph
http://www.nhtsa.dot.gov/Cars/Proble...per/Index.html
49 CFR Part 581, "The bumper standard," prescribes performance requirements for passenger cars in low-speed front and rear collisions. It applies to front and rear bumpers on passenger cars to prevent the damage to the car body and safety related equipment at barrier impact speeds of 2 mph across the full width and 1 mph on the corners.
No. The Federal bumper standard does not apply to vehicles other than passenger cars (i.e., sport utility vehicles (SUVs), minivans, or pickups trucks). The agency has chosen not to regulate bumper performance or elevation for these vehicle classes because of the potential compromise to the vehicle utility in operating on loading ramps and off road situations.
The agency concluded that reducing the impact speed from 5 mph to 2 front and rear impact speed best satisfied the statutory criteria that the bumper standard "seek to obtain maximum feasible reduction in costs to the public and to the consumer." The agency also concluded that reducing the impact speed to 2 mph and eliminating the Phase II damage criteria would not have an adverse effect on safety as measured by the number of crashes, deaths or injuries that occur annually.
Ironically, I think PVC can easily meet the weak 1.25mph standard... Auto industry lobbyists "for the lose"
post #11 of 33 Old 08-07-2008, 06:36 PM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
This is one of those things that I'll use my standard statement: feel free to kill yourself, but don't take others out in the process.
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #12 of 33 Old 08-07-2008, 07:24 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I'll take a stout bumper over a "crushable" bumper anyday of the week... I hit rocks alot more than I hit other vehicles.
At slow speeds, a crushable bumper on a Jeep might help some. A head-on into something at 60mph in a Jeep and I don't think it really matters what type of bumper you have.
My biggest fear (while driving my Jeep) is getting "T-Boned" in the side..
BESRK is offline
post #13 of 33 Old 08-07-2008, 09:04 PM
Unlimited04
you clearly know the answer already so why ask?
ditto. thats where the cage and rockers come in handy
Useful Write-Ups:
Funny:
post #14 of 33 Old 08-07-2008, 09:17 PM Thread Starter
winkosmosis
I don't know the answer. My license plate doesn't say Texas Truck on it. The feds could easily classify it as a car.
post #15 of 33 Old 08-10-2008, 11:20 PM
neatocj
neatocj's Avatar
1981 CJ5
Heres my solution. Remove the whole front bumper and watch where you are going. PVC eh thats a big mess to clean up.
Your not pushing the limits of your jeep until your on your side, then something breaks and it's time to go home.
'70 Camaro - Almost Done
'81 Cj-5 - SOLD
'06 MegaCab Cummins- Great White
neatocj is offline
run just a test pipe? 800dollarjeep Engines & Drivetrain 2 03-20-2012 06:56 PM
can you weld aluminum pipe to a stainless steel pipe? TXjeepTJ Fabrication Shop 16 03-05-2008 07:44 PM
Pipe Strength MeCasa Fabrication Shop 6 04-15-2006 08:27 PM
pipe bend this MyJeepisthebest Fabrication Shop 0 09-07-2005 02:47 PM
what size pipe T odd's J eep Fabrication Shop 3 02-09-2005 10:23 AM
