Oxy/Acet Cart Build - JeepForum.com
 2Likes
post #1 of 22 Old 08-12-2019, 09:06 PM Thread Starter
y2k-fxst
1964 CJ6
Oxy/Acet Cart Build
Finally decided I've done without a torch long enough. But, the carts I could afford I didn't like and, the carts I liked I couldn't afford! So spent the last couple days building a torch cart. Came out pretty good if I don't say so myself.
One thing I always cussed was the tool/junk tray that everything always falls out of when your moving it around. So, I made mine able to swing when moving.
Pretty well got the cart finished today. Just so damn humid wasn't sure if the paint would actually even dry. That and I couldn't talk myself into putting on the Tyvek suit and respirator! Will tear it apart and finish the cleanup when it's not near as humid out!
Storage for the striker and goggles on the left side.
Hose storage on the right side.
Even made the hose storage quick release. An idea I took from my wife's vacuum cleaner!
Even though I admittedly over built the cart. I'm real proud of how well balanced it is when moving considering I had no plans and was just cutting metal to what I was envisioning in my mind. Have used factory made carts that don't balance out as well always wanting to flip forward or has all the weight on your arms when moving them.
I own a Harley and a JEEP, still some people can't figure out why I'm broke!
y2k-fxst is offline
post #2 of 22 Old 08-12-2019, 09:41 PM
ravenworks
ravenworks's Avatar
Nice cart.
You should put a piece of angle iron on the front lip,it will enable you to easily roll the tanks on and off.
Also,you need a pieceof plate to separate the tanks from each other,it need to be as tall as you biggest tank.
Semper-Fi "81-84"
I.U.O.E. - 18
ravenworks is offline
post #3 of 22 Old 08-12-2019, 10:24 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Originally Posted by ravenworks View Post
Nice cart.
Also,you need a piece of plate to separate the tanks from each other,it need to be as tall as you biggest tank.
Why? Te commercial built ones do not have a divider.
The only thing I see wrong is the hanging goggles - that elastic strap always ends up stretched and useless after hanging for any length like that.
Rick
Cutlass327 is offline
post #4 of 22 Old 08-12-2019, 11:09 PM
ravenworks
ravenworks's Avatar
If you are using it in a commercial setting there has to be separation kept between the tanks to prevent dieseling which is rare but does happen.
I have been away from the industry for awhile but you local weld/Gas supplier could tell you.
Also,when storing tanks whether empty or full they need to be stored separate as well.
If you're using it around your house I wouldn't worry about,it is a nice cart.
Back when I was a kid,we had a huge body shop( like 200' x 200') and they had an explosion ( mob problems).
There were four 12 packs of tanks stored together inside, and when that building exploded it leveled everything within 300 feet and left a crater in the ground the size of the building that varied in depth 5 to 10 feet deep.
We lived like 5 miles away and it shook out house.
Not one person got killed.
God, the 70's were fun
Semper-Fi "81-84"
I.U.O.E. - 18
post #5 of 22 Old 08-13-2019, 06:21 AM Thread Starter
y2k-fxst
1964 CJ6
The commercial use ones have a divider. As far as the goggles go, they will probably be thrown in a drawer somewhere. I can't wear them other than in the middle of the winter. Normally just use my electronic welding helmet set for cutting.
y2k-fxst is offline
post #6 of 22 Old 08-13-2019, 06:29 AM Thread Starter
y2k-fxst
1964 CJ6
Nice cart.
Not sure what a piece of angle iron would do to make it easier to load and unload tanks? I raised the bottom plate up for stability when using it on gravel. That way the 4 legs hit and it not teetering on a rock under the plate like what happens with some I've used that have been basically a modified 2 wheel cart.
As far as the separator, I know it's not OSHA approved. Figure if I ever go into business I can always retrofit it with some sheet metal.
y2k-fxst is offline
post #7 of 22 Old 08-13-2019, 06:29 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Must be something new, as all of the ones I have seen do not.
78 CJ5 302HO, T177/D300, 86 WT 30/44, Aussie F/R
Rick
post #8 of 22 Old 08-13-2019, 08:50 AM Thread Starter
y2k-fxst
1964 CJ6
Yeah, new OSHA regulations. Lot of shops are having to switch to new carts. Problem is the OSHA approved ones start around $800 and go up from there! Acetylene is probably one of the most dangerous gasses in a shop. Primarily because people become compliant or aren't educated on it's use. Not sure of too many others that will self ignite if released at too high a rate.
y2k-fxst is offline
post #9 of 22 Old 08-13-2019, 10:11 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Many many years ago I was told not to operate the torch with the Acetylene tank laying down.
Something about exposing too much of the absorbent material releasing more Acetylene than normal.
Anyone hear of that?
I drive a Prius to save money and buy more Jeep Parts....
John Strenk is offline
post #10 of 22 Old 08-13-2019, 03:41 PM Thread Starter
y2k-fxst
1964 CJ6
Yeah, never operate an acetylene tank laying down, in fact don't use one that has been stored or transported horizontal for 24 hours after being placed upright. The acetylene is absorbed in acetone, the acetone will destroy your regulator if it get into it and can cause a fire if it gets in the lines. Same as using tips that are too large for the tank you have. If you are consuming acetylene faster than it can be released you will end up sucking acetone into the regulator.
y2k-fxst is offline
post #11 of 22 Old 08-13-2019, 06:20 PM
V8GCZJ
Nice cart but the one thing i see missing is PAINT!
V8GCZJ is offline
post #12 of 22 Old 08-14-2019, 08:38 AM Thread Starter
y2k-fxst
1964 CJ6
Yep, was so humid Monday when I finished it I couldn't talk myself into putting on a Tyvek suit and respirator.
Will be putting color on it soon. Kind of glad I didn't get color on it yet though. Got to thinking since it's so portable it's hard telling where all it will be used and might be a ways from the fire extinguisher in the shop. I picked up a 5# extinguisher today and I'm going to mount it to the back side of the cart. That way when I'm busy I don't have to remember to bring the extinguisher with me.
Cutlass327 likes this.
y2k-fxst is offline
post #13 of 22 Old 08-14-2019, 12:11 PM
Jim1611
Jim1611's Avatar
That's a nice cart. You may never need it but were it mine I'd want a way to pick it up with a forklift. Maybe bracket in the middle with an eye for hooking a chain too. Makes it easier to load in the back of a pickup.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #14 of 22 Old 08-14-2019, 08:33 PM Thread Starter
y2k-fxst
1964 CJ6
Yeah, don't have a fork lift to worry about lifting it with, or even a loader with a bucket. Don't plan on doing a lot of hauling it around and loading it in and out of the truck. Figure if it comes to it I can always add on to it, would probably go ahead and make an OSHA divider with a lift ring at the top.
y2k-fxst is offline
post #15 of 22 Old 08-14-2019, 08:35 PM Thread Starter
y2k-fxst
1964 CJ6
Will probably end up putting some 1 1/2" PVC pipe on eventually to hold brazing and welding rods also.
y2k-fxst is offline
