Got-trikes tubing benders - JeepForum.com
post #1 of 15 Old 08-04-2009, 10:43 PM Thread Starter
FortCollinsZJ
Im almost done with mine, anybody over here ever built one? Im excited to see it done, it has been a fun little project too. I strayed from the original plans a bit, but it's cool that you can.
I need to get a die from pro tools, a ram, and weld a few more tabs and it's done.
Here it is so far:
FortCollinsZJ is offline
post #2 of 15 Old 08-05-2009, 06:17 PM
GrantTJ
Wow, that looks great! I've always wanted to build one. Did you machine the parts in the first pic yourself, or have a machine shop cut them for you?
GrantTJ is offline
post #3 of 15 Old 08-05-2009, 06:48 PM Thread Starter
FortCollinsZJ
I bought cold roll flat stock, cut it to length with my chopsaw, used the template in the plans and drilled the holes on a drill press. VERY simple. The arms on the uprights are a different story. Those drilled easy, but were a PITA to line up when welding.
post #4 of 15 Old 08-17-2009, 08:09 PM Thread Starter
FortCollinsZJ
Almost done! I need to get a die and weld the upper die pivot tabs on, then it's all ready to bend!
post #5 of 15 Old 11-21-2010, 07:53 AM
cklanish88mj
what is total cost to build minus dies ?
cklanish88mj is offline
post #6 of 15 Old 11-21-2010, 08:55 AM
jatepper
jatepper's Avatar
You MUST share with me those plans! I really need to get one and I'd rather build one myself if at all possible!
Too many Jeeps to count....
jatepper is offline
post #7 of 15 Old 11-21-2010, 09:05 AM
rlockwood
the plans are $17, ultimately a drop in the bucket when compared with the overall cost of building it.
When I get further along, i'll probably post some pics. Not much to see so far, just have the holes drilled for the uprights, and most pieces cut to length/mitered. Its a slow project for me
rlockwood is offline
post #8 of 15 Old 11-21-2010, 09:45 AM
jatepper
jatepper's Avatar
I just bought the plans. I figured for $17 what do I have to lose? I need to get a bender as I sell bumpers locally and I have had numerous request for bull bars, etc.
It looks like a decent bender and the best part is that I can put it on wheels and move it around.
jatepper is offline
post #9 of 15 Old 11-21-2010, 10:46 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Looks real nice!
Joe Dillard is offline
post #10 of 15 Old 11-21-2010, 12:27 PM
tangotag
Old thread 08/09
How is the bender working out?
I had the old plans, upgraded to the newer plans and already bought the 8 ton Air/Hydraulic long ram about 2 years ago. I just haven't got started on it yet.
It's about time I get going and build mine.
The nice thing with these is you load the tubing on a horizontal plane so you can use an inexpensive magnetic digital protractor for a very accurate bends.
You can do your bends anywhere even outside when space is tight and not need to bolt anything down to your shop floor. When not in use it can be tucked away, which is a big plus for a small shop.
tangotag is offline
post #11 of 15 Old 11-21-2010, 07:34 PM Thread Starter
FortCollinsZJ
Originally Posted by tangotag View Post
Old thread 08/09
It is nice that you insert the tube on a horizontal, but its a lot nicer that it bends on a vertical plane. I used an expensive JMR bender to bend some doors, and with only three bends on one door, neither came out flat. I used my own bender to put 6 bends in one tube (roof halo) and they lay all lay paper flat on a concrete floor.
I have used the hell out of this bender, and it has done everything I have asked it to do without a hiccup. Built a roll bar for an S200, a few jeep bumpers, a Toyota bumper and built myself an internal cage. The only issue I am having, is with the hose on the HF ram, it is dry rotted badly and ozone is eating it way. It leaks a bit if kinked at all. I need to fix that.
You will be satisfied with the bender, if built right and used correctly.
post #12 of 15 Old 11-21-2010, 07:52 PM Thread Starter
FortCollinsZJ
The prices are what I paid when building the bender a year ago, maybe a bit different now.
Steel, includes all the cold roll plate, aswell as the 2x2 structural: $130-140
Bushing kit from the plans site: 50.00 shipped ( he had a sale for the summer for 40$ instead of 60$ now)
Grade 8 1" bolt 12" shank: 14.00 and change
Grade 8 7/8" bolt 12" shank: 11.00 and change
So total is close to 200 for the bender hard parts, WITHOUT the Air/Hydro ram, and cost of plans. Ad in cost of paint and casters, Which I had already.
Air/hydro ram form HF: 85.00 out the door (used a coupon and saved 15%)
With ram and 1.5" die= 542.00, so just under or colse to 550.00 for a bender with a air/hydro setup AND a die.
post #13 of 15 Old 11-22-2010, 04:32 AM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
Do you have a link for the plans?
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #14 of 15 Old 11-22-2010, 06:34 AM
Jim1611
Jim1611's Avatar
Nice job on the fab work.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #15 of 15 Old 11-22-2010, 07:10 AM
tangotag
Got_trikes
More specifically the page for the bender.
http://www.gottrikes.com/Tube_Bender.htm
tangotag is offline
Tube benders tbick Fabrication Shop 26 04-09-2009 02:26 PM
What tubing to use skywalker2117 Fabrication Shop 5 02-10-2009 05:49 AM
Has anyone used this tubing bender? jeepsterjc Fabrication Shop 10 02-04-2009 08:48 PM
Pre-fab tubing mike481 Fabrication Shop 5 08-08-2006 11:34 PM
tube benders rhino1 Fabrication Shop 11 01-28-2005 07:45 PM
