extending firewall/ - JeepForum.com
 2Likes
  • 1 Post By JeeperDon
  • 1 Post By Fourtrail
post #1 of 6 Old 05-05-2019, 10:26 PM Thread Starter
yjpadawan
extending firewall/
This is my first vehicle doing real fab on so I need help making sure I'm not over looking anything.
I essentially turned my YJ into a CJ. I ripped out the heater and have a 318LA engine now (distributor is with in fractions of an inch of firewall.) I placed heater in the center because passenger side gives me some issues with battery tray and if I place it higher on firewall, like I would like to, Im not sure there is room behind the glove box. The outlets for my heater core are now where my distributor is. ( Didn't see this until the end.)
My idea is to add a rectangular extension to the center towards the cab. Give the fire wall an additional 4ish inches in the center on the engine side. Allowing my coolant lines to be routed around the distributor.
Any thing wrong with this besides the fact water being so close to electrical.
You guys have a better idea for heater location?
heater is 7.0625 in. H x 7.4375 in. W x 7.375 in. D
Heater link
https://www.jegs.com/i/JEGS/555/70603/10002/-1
yjpadawan is offline
post #2 of 6 Old 05-05-2019, 10:29 PM Thread Starter
yjpadawan
pics
post #3 of 6 Old 05-06-2019, 07:40 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
You swapped the motor and heater, and basing those decisions on not messing up the glove box? It has to move, motor comes first. You don't live in AZ, heater comes next. Get those done right then come back and ask "Where can I put my gloves?"
Mud Machine likes this.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #4 of 6 Old 05-06-2019, 02:16 PM Thread Starter
yjpadawan
I don't have an option to move my glove box either because its a CNC cut dash. So the somewhat easiest solution I saw was to move the firewall back.
post #5 of 6 Old 05-06-2019, 04:23 PM
Fourtrail
1974 CJ6
the easiest would be to call a plumber and have him change where the heater hose connections come out of the box to a different location on the firewall. going to a close 90 degree elbow and spacing the heater away from the firewall is easier than cutting up the firewall.
222Doc likes this.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is online now
post #6 of 6 Old 05-06-2019, 06:45 PM
JeeperDon
JeeperDon's Avatar
At this point in your project, since the glove box is the main thing in the way, I'd make the glove box part behind its door a lot smaller. Maybe just a small tip out bin attached to the door. The photo is for a kitchen sink, but helps show you what I'm thinking. I'd leave the firewall alone.
Web Admin for
Factory firewall wire harness Bdavis100200 Jeep CJ Forum 7 02-22-2019 10:20 PM
84 XJ split in firewall ct1552 XJ Cherokee Technical Forum 2 02-06-2019 08:05 AM
Engine and Firewall Clearance Geek Jeep CJ Forum 9 12-23-2018 01:18 PM
Firewall water leak Wrangler95CSA YJ Wrangler Technical Forum 16 09-19-2018 09:43 PM
Curious: CJ7 Firewall & Cowl To YJ deminimis Jeep CJ Forum 1 12-14-2017 03:06 PM
