Cold welding - JeepForum.com
post #1 of 5 Old 06-24-2020, 08:11 AM Thread Starter
Splinter
1980 CJ5
Cold welding
You must have seen videos of a cold welding process coming out of China. It’s also called crazy welding. I cannot find a source for the machines but I think it would work well for welding thin panels. Any comments
Splinter is offline
post #2 of 5 Old 06-26-2020, 11:28 PM
mukluk
mukluk's Avatar
Technically it's not cold welding since it is using heat to melt the parts together. True cold welding uses a cleaning process and then pressure to weld the parts together.
Migatronic Tig-A-Tack
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #3 of 5 Old 06-27-2020, 05:17 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
I work in an aerospace welding shop, and thin panel sheet metal welding with a TIG machine is simply the correct settings, and the right technique. Automotive body panel welding can be done with a brand name mid-grade wire feed, use the correct settings, just develop a good technique, and take your time. Numerous small welds with some cooling time will do the job without excessive distortion. You should look at GoJeeps website about his Willys hot rod, ( http://willyshotrod.com ) he goes into great detail about metal forming, metal shrinking, and finishing weld distortion with a hammer and dolly.
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
post #4 of 5 Old 06-28-2020, 10:43 PM Thread Starter
Splinter
1980 CJ5
So Tim. Can you comment on the videos out of China on the process. I think this welding process would be excellent for my body work requirements
Splinter is offline
post #5 of 5 Old 06-29-2020, 12:15 PM
mukluk
mukluk's Avatar
It's not something new coming out of China, it's tack welding using a TIG, and the welding machine in question uses software to restrict the duration of the weld to attain a consistent result. If you looked at the link and video I provided earlier, you'd see this specific setup has been around since at least 2012 and who makes it.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
