Attention Welders... - JeepForum.com
post #1 of 5 Old 10-23-2019, 08:52 PM Thread Starter
HVACman
Mmmmmm.... Milk!
HVACman's Avatar
Question:
I'm doing the WJ brake swap on my ZJ and I need to weld a spacer to the WJ knuckle. Looking at youtube videos, it was recommended to use 308L stainless MIG wire for welding the spacer to the knuckle. I ordered a 2lb roll per the product description on Amazon but I received ER308.
Is there a difference that I need to be concerned with or can I use it?
Is the video that I watched wrong and should I be using a different MIG wire all together? (I'm aware of the pre-heating and slow cooling processs required)
Thanks!
Experience. It's what you get when you don't get what you want.
A beaver without a pelt is like a peacock without feathers.
Memberships: California Association Of 4WD Clubs - Friends Of The Rubicon - The Blue Ribbon Coalition
K6CKR
Originally Posted by Grape Ape
How many times have we told you . DON"T DUMP THE BODIES CLOSE TO YOUR HOME!!
HVACman is offline
post #2 of 5 Old 10-26-2019, 03:17 PM
222Doc
222Doc's Avatar
no expert and i only stick weld but it seems odd to use stainless on steel that is cast?. i would use just old 7018 on my Lincoln 220 that i have a long time. about all i use anyway.
maybe someone that is a pro could jump in. But this section tends to be kinda dead at times.
222Doc is offline
post #3 of 5 Old 10-26-2019, 09:46 PM
ravenworks
ravenworks's Avatar
You'll want to use something with a high NICKEL content.
If it were me I'd buy locally from a weld supply shop.
Semper-Fi "81-84"
I.U.O.E. - 18
ravenworks is offline
post #4 of 5 Old 10-30-2019, 02:22 PM
Waternut
Waternut's Avatar
I welded mine with regular flux core wire.... Realistically, if you didn't even weld that spacer, you'd be fine. You're just sandwiching the spacer between the unit bearing and the knuckle and torquing the 3 bolts down super tight. The spacer can't even move until you shear all 3 bolts and the spacing is going to be pretty trivial at that point. Welding does make things a lot easier during installation and safer if the bolts get loose but neither of those are really going to make you crash unless you screwed something else up first.
Waternut is offline
post #5 of 5 Old 12-08-2019, 01:07 PM
77amc
1981 FSJ Cherokee
You need a high nickel content of the filler wire/rod.
BUT welding cast iron, you need to heat the part being welded, and slowly cool. Otherwise it can produce tiny little fractures, compromising the cast item. And depending on use, could cause a life threatening situation.
But like he said, it's all sandwiched between there, so I'd probably just get new bolts and med thread locker.
77amc is offline
