Add towing hitch... rear bumper welded on - JeepForum.com
post #1 of 4 Old 05-17-2019, 07:43 PM Thread Starter
ahalvorson
Just picked up a YJ. Prior owner welded custom steel rear bumper to the frame.
Any ideas how to add a towing hitch?
Thanks!!
Aaron
ahalvorson is offline
post #2 of 4 Old 05-17-2019, 09:45 PM
Mattific
Mattific's Avatar
Any pictures of it? A standard bolt on hitch may still fit depending on the bumper but you would lose some departure angle if that matters to you
Mattific is offline
post #3 of 4 Old 05-19-2019, 08:55 AM Thread Starter
ahalvorson
Sure! Here are images of the bumper and the weld points
post #4 of 4 Old 08-01-2019, 02:51 PM
strykersd
Do you have access to a welder? If you do, I would first cut some triangles to connect your frame to your bumper to help with lateral loads. Then I would buy a hitch, trace the square where you want it on the bumper and then drill four holes, one for each corner of the square. Then use a angle grinder to cut the sides of the square out from hole to hole. Then weld the hitch in place.
If you don't, I'd still have someone weld on some triangular supports for your bumper and buy a bolt on hitch from etrailer .com
strykersd is offline
February 2019 YJOTM - Vote Now! bruinjeeper YJ Wrangler Technical Forum 37 03-04-2019 08:03 PM
August 2018 YJOTM - VOTE NOW!! bruinjeeper YJ Wrangler Technical Forum 39 09-03-2018 06:42 AM
Will A Laredo Rear Bumper Fit A Limited? BeefyJeep WJ Grand Cherokee Forum 5 08-16-2018 08:12 AM
Need pics of rear bumper tie in Mike128 YJ Wrangler Technical Forum 14 03-10-2018 09:48 AM
CrankyGypsy's 2004 Rubicon CrankyGypsy Jeep Builds 33 05-14-2017 09:03 PM
