95 YJ floor supports /body mounts. - JeepForum.com
post #1 of 2 Old 12-11-2019, 08:27 PM Thread Starter
Gallent
Gallent's Avatar
I need the dimensions of the body mount above the fuel tank that is Welded to the TUB... not the cross sill... there is a rectangle piece "floor support" that is about 5' long.. I need that correct length, and 3/4 to 1" high and roughly 3-5 inches wide... I need the correct dimensions so i can drop the tank and either make a cap or completely replace this part. My body mounts went through the floor pan, under the back seat. they also went through the outboard floor supports which i can purchase online for about $50-60 each.
I just cannot find the floor support that goes above the fuel tank. above the rear tires.
any ideas on how to repair? should i use 16gauge or 14 guage steel. ?? and if i replace it should i use some bracing on the back side to give it more strength?
I am currently still driving the Jeep, but am not doing any offroading, until these things are reparired.
here is a picture i borrowed from the NET.. It is not mine, just for reference. Apologies if it is yours , and thank you for letting me borrow...
I added drawings to it to show what i am looking for...
Gallent is offline
post #2 of 2 Old 03-10-2020, 10:58 AM
Tinker0000
I figure at this point, you've already found what you needed. But if not, Here you are.... https://www.classicent.com/products/...pport-yj-87-95
Tinker0000 is offline
