88 YJ soft top spreader upgrade - JeepForum.com
post #1 of 1 Old 06-29-2007, 11:56 PM Thread Starter
4.7stroker
4.7stroker's Avatar
Hi all,
My soft top spreader bars were shot so while walking around home despots I realized that with some 1/2 emt I could make some new non failing spreaders for $5 and about 30mins of work.
Well I get it home measure once and cut it righ the first time.
They were 31" on my 88 Heep so I cut the emt to 33" and flattened each end about a inch.
I then drilled a 1/4" hole in each end spaced 31.5" apart. This gave me a little more stretch and really tightned things up.
Well 2 days later the back spreader mount breaks so I get 2 2" long 1/4 X20 coach bolts nuts n washers. Coach bolts have a nice round head so they won't damage my new sail cloth top and they are galvanized so they won't rust.
I then drill the hoop that the spreaders were mounted to (after removing the top) and old mounting hardware, install the coach bolt with 2 nuts to provide the required spacing.
The protruding bolt gives me a solid mount for the rear of the spreaders, secure with a washer n nut.
All is solid cant fail top is nice n tight and I am a happy camper.
Im sure anyone that has had to jerry rig the old broken setup will know what I am talking about and will be able to duplicate my repair if needed.
If you have any questions just ask I may be able to shoot some pics if needed.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
Want to stealth upgrade my previous audio upgrade Peregrine777 Audio, CB & Ham Radios, GPS, & Electrical 17 12-30-2009 07:33 PM
Need a hilift extreme top clamp/ spreader attachment 2ez4Robert General Jeep & Off-Road Equipment 7 07-07-2009 06:32 AM
Cheap fix for soft top spreader bars that won't stay hinged. 93YJfalcon Cheap Tricks & Fixes 3 03-18-2009 05:32 AM
Black soft 8's or Silver soft 8's? CHRRRIS Tires & Wheels 3 02-22-2008 07:42 PM
Spreader bars DogHouse Fabrication Shop 0 05-28-2007 05:57 PM
