starter rebuild - JeepForum.com
post #1 of 3 Old 02-25-2019, 07:25 AM Thread Starter
Ross
starter rebuild
I did a search and got this: "Sorry - no matches. Please try some different terms."
My starter is make a grinding noise, pretty sure it is the starter gear/Bendix not moving as it should. Has anybody successfully fixed this issue. Could it be an electrical issue or just the starter gear hanging up and not moving back into the starter as it should
My Jeep is a 2001 TJ 4.0 5 spd.
01TJ33sWarn,ARBs F&R,bellyup,4.0,4.56s,5spd
99 XJ33sWinch,Electric locker up front,4.56s,4.0Auto
Ross is offline
post #2 of 3 Old 02-28-2019, 07:08 PM
V8GCZJ
How long has it been "grinding"? If it was a long time you could have damaged the ring gear. The "grinding" happens when the bendix doesn't pull in all the way. But if the teeth on the ring gear are damaged even a new starter won't fix that. The ring gear will need to be replaced.
V8GCZJ is offline
post #3 of 3 Old 03-01-2019, 04:20 AM Thread Starter
Ross
The issue was exactly as you stated. I was hoping to just clean out the Bendix but I just replaced it. A few of the teeth were nicked but it makes no noise when I start it with the new starter. As soon as I heard it grinding I changed it the next day.
Ross is offline
Project CJ7 "PJ edition" complete rebuild ! KristPJ Jeep CJ Forum 99 05-05-2020 07:55 AM
Project CJ7 "PJ edition" complete rebuild ! KristPJ Jeep Builds 82 05-03-2020 07:52 AM
2002 WJ 4.7 Starter Not Turning Over losOsos WJ Grand Cherokee Forum 0 02-14-2019 09:42 PM
Starter question 09KK4X4 KK Liberty Forum 2 10-10-2018 09:31 AM
95 ZJ won't start, crank, or turnover. Battery, starter good. New starter relay hansoulow ZJ Grand Cherokee Forum 5 04-06-2018 05:38 PM
