2008 d60's??? - JeepForum.com
 1Likes
  • 1 Post By youngjeepr
post #1 of 10 Old 08-28-2016, 08:00 PM Thread Starter
XJK
The Guru of Nothing
XJK's Avatar
2008 d60's???
Any negative issues with 08 ford d60's that I should know about in comparison to the older 60's?
It's Not Just a Jeep, It's a Lifestyle
XJK is offline
post #2 of 10 Old 08-30-2016, 07:18 PM
jason m
Nothing but the facts
jason m's Avatar
Yes a real short side tube to work with and lots of cast section parts in the way. But I like the fact that the knuckles are huge and I'm pretty sure 1550 u-joints can be installed.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is offline
post #3 of 10 Old 09-01-2016, 02:00 PM
youngjeepr
youngjeepr's Avatar
I'll be swapping a 05+ d60/10.5 into an LJ later this year. But the driver side tube is almost non existent because it's so short and there is A LOT of castings on it.
88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
youngjeepr is offline
post #4 of 10 Old 09-24-2016, 11:08 AM
Luke95
Run it. Run the rough stuff kit to build long arms for it using the bushings and a custom track bar and steering.
97 XJ on 4Ds.
Luke95 is offline
post #5 of 10 Old 10-05-2016, 09:53 AM
youngjeepr
youngjeepr's Avatar
Just finished this set
Teeshock likes this.
post #6 of 10 Old 10-05-2016, 09:53 AM
youngjeepr
youngjeepr's Avatar
Sterling 10.5
post #7 of 10 Old 10-22-2016, 06:46 AM
Teeshock
Other than the cast issue, is the labor involved on a Dana 60 super duty front axle the same for 99-04 and 05-2010? Should I pay a couple hundred more for an 05+?
Sent from my SAMSUNG-SM-G890A using Tapatalk
Teeshock is offline
post #8 of 10 Old 10-22-2016, 09:17 AM
youngjeepr
youngjeepr's Avatar
Originally Posted by Teeshock
Other than the cast issue, is the labor involved on a Dana 60 super duty front axle the same for 99-04 and 05-2010? Should I pay a couple hundred more for an 05+? Sent from my SAMSUNG-SM-G890A using Tapatalk
I'm not sure.. I haven't built a 99-04 axle. But the 05+ d60 really isn't bad to build if you know how to use a torch, grinder, and a welder. It took me 6-7 hours to have that set done start to finish.
post #9 of 10 Old 11-08-2016, 01:28 PM
youngjeepr
youngjeepr's Avatar
I just picked up a 99-04 axle today and will probably build it in the next few days so I'll post back and let you know.
post #10 of 10 Old 11-14-2016, 05:50 PM
youngjeepr
youngjeepr's Avatar
I haven't got the truss put on yet. But to clean all the dirt off (wire wheel) and cut the brackets off and tear it down to just the housing took 4-5 hours.
So I would say the 99-04 and the 05+ axles take about the same amount of time. The 05+ axles might take a bit longer just because of the big cast radius arm mount.
