2000 grand Cherokee limited 4.7 45rfe p750 - JeepForum.com
post #1 of 3 Old 06-30-2019, 09:56 PM Thread Starter
Patrockyj
Passenger side shock failed, shock shaft rubbed wiring for tcm to failure. So far new TCM soldiered all broken wires, from shock shaft. New solenoid pack, pressure sensor transducer, front and rear speed sensor and new pcm new 30a fuse and relay? Still throwing a p0750 and has a buzz in P and N until warm. Tps tests good. Any help is appreciated. Fluid is correct +4 and added 9 qts to get correct hot cold levels. I am at my wits end, also replaced both filters making certain the lower filter, has ring pressed properly, then filter installed, help
Patrockyj is offline
post #2 of 3 Old 07-01-2019, 05:13 AM
jtec
2014 JK Wrangler
are you using a scanner?
sounds like TCM is not seeing 12v on circuit T150.
CHECK CASE CONNECTOR TO TCM #50
jtec is offline
post #3 of 3 Old 07-02-2019, 09:32 AM Thread Starter
Patrockyj
Thank you so much what was he image you posted it is not letting me see the picture
