Jeep Grand Cherokee WK2 GCC Specs Jeep Registry
Previous Jeep WK2 Grand Cherokee Next Jeep
Email Bookmark Print
oltei
Jeep Information
Year:2020
Model:Grand Cherokee, Laredo Trim
Engine:3.6
Transmission:4x2
Hello friends,
I need a piece of advice: I live in Saudi Arabia where during summer, temperature between 45-50 degrees are normal. I will leave the country for almost two months and the car will be staying under the sun (protected only by a car cover). Question is: should I remove the battery before I leave and store it inside the house? Will it still be usable once I return? Since the CPU will be without power, what will happen when I connect the battery back? (the car is bought about 6 months back)
Any other tips that I should be aware of? I searched online about removing and adding back the battery but I could not find any advice about this particular topic).
Thank you,
Andrei
None
Login Or Register To Post Comments
Jd41wk2
View Jd41wk2's Jeep
06-06-2021, 06:28 PM
Originally Posted by oltei View Post
Hello friends,
Thank you,
Andrei
It's not a hop skip and a jump to disconnect the battery... if you're dead set on it put a battery tender on the Jumpstart points of the car or the battery terminals themselves. It's tough to get to it bc it's under the passenger seat
Sent from my SM-N975U1 using Tapatalk
