Hudson Valley - Page 77 - JeepForum.com
post #1141 of 7919 Old 09-25-2009, 09:28 AM
RidinNY
Let me know where there is a nice one for $450 and I will go buy it.. That's a good deal if it is a factory unit in good shape.
DILLIGAF - Balls Deep (or no balls at all)
2002 T J- X model on 31" Firestone Destination MT
87 XJ Pioneer 6" lift 33" Super Swamper TSL
RidinNY is offline
post #1142 of 7919 Old 09-25-2009, 01:34 PM
XaphanZ
if i don't end up buying it, i'll share info, but if i can't find a better deal before tomorrow, i'm coming home with it.
XaphanZ is offline
post #1143 of 7919 Old 09-25-2009, 09:15 PM
XaphanZ
is it still a good deal if it's a bestop in good shape? i hope so... i bought it
XaphanZ is offline
post #1144 of 7919 Old 09-26-2009, 07:42 AM
Kenbo-Slice
Kenbo-Slice's Avatar
I hope you bought it! I was going to say, if you needed a hardtop and were are trying to find one for a TJ for less than $450 you would be very hardpressed. Not to mention upset when someone else bought the one you passed up! $450 is a great deal as long as it is in pretty good shape. Bestop or factory, tinted windows or clear.... I already have a hard top, and I would have bought that just to re-sell, haha!
Jeep build up...ONGOING
Kenbo-Slice is offline
post #1145 of 7919 Old 09-26-2009, 10:12 AM
XaphanZ
sweet. yeah, it's got tinted windows. i have to figure out how to uninstall the soft top and get this thing bolted up today. curious.... any reason the soft top needs to come out? any harm in leaving both tops on?
XaphanZ is offline
post #1146 of 7919 Old 09-26-2009, 05:51 PM
_TIM_
_TIM_'s Avatar
You should take the soft top off, just fold it down and there should be 4 spots where it connects to the roll cage. Just unbolt it and take it off.
Having the soft top on with the hard top will just get in the way when you open the back.
1998 tj|chili pepper red|
_TIM_ is offline
post #1147 of 7919 Old 09-28-2009, 10:49 AM
helicase50
helicase50's Avatar
Remember where you put the parts for the soft top. That was my issue this summer!
A big THANK YOU to AmbuGrl and Mudvain for upgrading me.
Yes, I'm a girl, I drive a TJ and like to get it dirty. Yes, I like boys. Get over it.
Live Fun, Ride Fast, Die Pretty ~ Chic Riders M
Originally Posted by vindicated View Post
Did I ever mention I loved you? :kiss:
Originally Posted by Sarahdactyl View Post
Hey! That's my woman you're hitting on there! <:mad:>
Be Jealous
helicase50 is offline
post #1148 of 7919 Old 09-28-2009, 08:12 PM
Irongrave
Irongrave's Avatar
any one want to help put on a JCR bumper onto my XJ saterday, pizza and beverages provided.
Current
2002 WJ 2wd DD
Irongrave is offline
post #1149 of 7919 Old 09-28-2009, 09:04 PM
Kenbo-Slice
I believe I still have your number. I may be able to help out Drew, I'll let ya know.
post #1150 of 7919 Old 09-30-2009, 08:47 PM
mgtsldr
Hey guys, Im trying to get my front end aligned, but from what my dad is telling me, the tires are out like 7 degrees and the auto shop wouldnt do anything for it, went to a guy that bends axles to fix it and said he cant fix that much. So Im under the assumption I have to cut my knuckles off and re-weld them on at a different angle to make everything straight? Does anybody know a place local that does this kind of axle work? Its a ford d44 if that matters at all.
94 wrangler - flat black, 350 SB, 44/60, SOA, 35" boggers, 36" military specs, 39" mickey thompsons
mgtsldr is offline
post #1151 of 7919 Old 10-01-2009, 06:15 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Originally Posted by mgtsldr View Post
...the tires are out like 7 degrees...
Did any alignment shop actually measure it? Not to be one dad questioning another, but my eye's are not calibrated that closely. You also didn't mention if you are seeing any odd handling or tire wear.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #1152 of 7919 Old 10-01-2009, 01:10 PM
mgtsldr
Im not quite sure what my dad did, Im 2 hours away so I cant really watch him, but he didnt just look at it and figure the degrees. The tires seem to be tilted out at the top quite a bit, and while driving down the road it just seems to be all over the place. Its hard for me to explain it, you just have to drive it to eperience it, haha.
mgtsldr is offline
post #1153 of 7919 Old 10-01-2009, 02:08 PM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
so you're dealing with 7 degrees of positive camber? that sounds kind of weird because the load on the axle will usually bend the tubes the other way, creating a negative camber angle. the ground pushes up on the tires while the weight of the jeep on the springs pushes down on the tube to make the axle bow like a smile when looking at the jeep from front or back. just like walking on a board supported at the ends. in order to bend the other way, the forces would have to reverse and short of landing the tubes on a rock or stump oir something like that a couple times I can't see how you would bend the axle that way to get the kind of angles you're looking at. have you checked the ball joints and the hub bearings?
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #1154 of 7919 Old 10-01-2009, 06:12 PM
Irongrave
Irongrave's Avatar
bump for help with installing new bumper on my XJ this sat
got the old bumper off the XJ today
before
After
The new bumper all painted and ready to go
Current
2002 WJ 2wd DD
post #1155 of 7919 Old 10-01-2009, 07:33 PM
YJames90
YJames90's Avatar
Originally Posted by Kenbo-Slice View Post
My fathers boss has a shop about 1 mile down the road. I could get plenty of parking there, and maybe across the street as well. As long as I touch base with him first. When the time gets closer Ill set it up and let you guys know. Its "only" 11 acres which sounds like a lot, but groups of more than 6 or 7 can get a bit cramped. I have to talk to my friend and see what he wants to do when the time gets closer, and we will go from there.
Any more info on this and will you be at the next HV meeting?
My 2.5 to 4.3 swap thread
YJames90 is offline
Legal playgrounds in Hudson Valley NY 96-XJ North East USA 11 01-10-2010 02:44 PM
Hudson valley help, sadass North East USA 10 12-14-2008 09:49 AM
Panamint Valley - Dec 19,20,21 L8 APEKS California Jeep Forum 0 12-13-2008 07:47 AM
Johnson Valley 1whitetj California Jeep Forum 1 12-11-2008 08:38 PM
Hungry Valley 12/29/07 jrod196 California Jeep Forum 11 01-02-2008 04:56 PM
