Good mechanic in the Katy area - JeepForum.com
post #1 of 4 Old 02-09-2019, 08:11 PM Thread Starter
DavidSoUr
Hey guys,
I'm working on importing my dad's old CJ7 from Mexico and would like to get it into shape for driving around town. Does anyone have any suggestions for a good shop I could use in the Katy area?
There's no plans for any modding on this one, but I do need a mechanic that knows enough about old jeeps; it's been sitting in storage for over 5 years and I don't know much about what's already been done to it. I know the drive train was modified to accommodate an AMC 304 V8, so there's quite a bit non-stock under the hood.
I might be looking to install a 3 point seat-belt by having the shoulder strap bolt added to the stock roll bar. Does anyone know a good shop that would be able to drill and weld this in the area?
Thanks
DavidSoUr is offline
post #2 of 4 Old 02-10-2019, 07:10 AM
DocAdams1
2016 JK Wrangler
Not sure on a local mechanic, but the AMC 304/401 were standard options. It may be original. I have owned several CJ5s and they are a pretty straight forward vehicle.
DocAdams1 is offline
post #3 of 4 Old 02-10-2019, 08:10 AM Thread Starter
DavidSoUr
I think it was already an option for the 81 CJ7, but it's obvious from the way the engine is mounted on mine that it is not from factory on this one. I also remember some talk about it at home back when the mod was done, but I was too young back then to pay any attention.
post #4 of 4 Old 02-10-2019, 06:31 PM
DocAdams1
2016 JK Wrangler
are you just needing to have it freshened up since it was stored or is there an actual issue with it? The reason I ask is because the AMC 304 is an easy motor to work on and parts are readily available. Unlike the modern mess of electronics, there really isn't much to worry about. If you are just freshening it up you can easily do it over a weekend.
1. Drain/ Refill fuel
2. Change Oil
3. Clean Carb
4. Rebuild Ignition (plugs/wires/coil/rotor/distro cap)
5. Change Air filter
As for the rest of the drive line pretty much a drain and fill should be good.
12 Things You Can Do When Your ZJ Stalls ZeeJay1997 ZJ Grand Cherokee Forum 451 07-29-2021 07:16 PM
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3867 02-23-2021 12:07 PM
New study says 46% of Bay Area residents plan to leave in the next few years SDDAVE Politics, Religion & Controversy 12 06-27-2018 08:23 PM
where to post / find a mechanic bergovoy California Jeep Forum 3 03-13-2018 04:55 PM
