Driveline vibration - JeepForum.com
post #1 of 9 Old 06-05-2019, 02:49 PM Thread Starter
jeepichigo12
Driveline vibration
Got a 4 inch lift and didnt know the front driveshaft needed to be changed to a different style. Drove to 500 miles till I could get a custom Tommy driveshaft. When I finally swapped it out the drive line vibration got better but was still there so I went to look at the front axle and the fluid looks burnt and the seal looks like its started leaking. Bearings maybe?
Sent from my SM-G955U using Tapatalk
jeepichigo12 is offline
post #2 of 9 Old 06-10-2019, 08:19 PM
DocAdams1
2016 JK Wrangler
What type jeep do you have? I am assuming that you are running a wrangler. On solid axles when you add lift you change the caster angle, adjustable control arms will allow you to change the caster angle.
DocAdams1 is offline
post #3 of 9 Old 06-10-2019, 08:22 PM Thread Starter
jeepichigo12
I'm running a wj and the pinion angle is way off but the fluid looks burnt. Hoping correcting the angle fixes the issue
post #4 of 9 Old 06-10-2019, 08:35 PM
DocAdams1
2016 JK Wrangler
I am not familiar with the set up on the WJ. How far off is the pinion angle? The fluid could have been a bit burned before the change, but could be a sign of excess heat due to the fluid not lubricating/ cooling due to the change in angle(fluid level/position)
post #5 of 9 Old 06-10-2019, 09:36 PM Thread Starter
jeepichigo12
It's similar to wrangler. Dana 30 front, Dana 44hd rear and np247 tcase. Had the shop check it out and he said it's so far off his eyes hurt and 3 months prior to that it was rebuilt and had 4.11 gears installed
post #6 of 9 Old 06-11-2019, 09:39 PM
DocAdams1
2016 JK Wrangler
Was the fluid changed after break in? Did they correct the pinion angle?
post #7 of 9 Old 06-11-2019, 10:14 PM Thread Starter
jeepichigo12
Yea I changed it with royal purple 75-140 and they did in the rear but only said it needs a different driveshaft which I put on it
post #8 of 9 Old 06-11-2019, 10:46 PM
222Doc
222Doc's Avatar
you say someone put 4.1 gears in it. smells burnt. when new gears are set you must brake them in, keep under 220 is max would rather see maybe 180 at 220 the oil is cooked, done. as well if set wrong can lead to the same end. Both end up galling. Vibration could be a bearing . is there any lateral play at pinion? should be nearly impossible to move laterally.
new gears should have the oil changed after break in. that is as well when you check how they broke in. they lap and leave metal best to get that out no more then 1k i say i tend do it at 700 just did the truck and it takes 1.25 gallons. gears look good enough to tow when they get to about 1k heat cycling is how you break them in not at high speed long distance.
so this type jeep has no CD shaft front? must have been CV razzapa style? did it break a seal and toss grease? two joint old type if it vibes badly enough can ruin a bearing at either end. even end catastrophically.
222Doc is offline
post #9 of 9 Old Yesterday, 08:12 PM Thread Starter
jeepichigo12
No I changed the driveshaft to have a double u joint on both ends from Tommy custom shafts and the pinion angle is just off but the shop that did it is telling me its beyond their capability to get correct
