WK does not accelerate over 1500 rpm - JeepForum.com
post #1 of 4 Old 09-25-2021, 11:10 AM Thread Starter
Trotineta
I replace the actuator on my turbo. P0046 is gone but still no acceleration over 1500 rpm. Found the turbo intake hose broken. Could this be the issue? Could it be turbo issues( mechanical)? Do I need to reset the PCM and/ or ECU?
Trotineta is offline
post #2 of 4 Old 09-25-2021, 05:30 PM
Bigrigr
Bigrigr's Avatar
Leaks in the turbo piping will definatley cause a loss of power. Repair the leak, and see what you get then....
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,4" short arm lift,JK'sW/32's
Bigrigr is offline
post #3 of 4 Old 09-25-2021, 07:48 PM Thread Starter
Trotineta
I will buy one Monday. The question is; how much damage a piece of broken gasket could do to the engine. If is it inside the turbo where could it go? Could intake blades cut it in pieces and push it in the engine? Did it burn? There is no axel movement on the intake side of the turbo
post #4 of 4 Old 09-25-2021, 08:26 PM
WJ60
WJ60's Avatar
You might get far more help in the WK forum.
'77 Chevy C10 pickup
'01 WJ 60th Anniversary Edition
'13 Dodge Dart Rallye
WJ60 is offline
