WJ Windshield Wipers Issues - Page 2 - JeepForum.com
post #16 of 24 Old 04-04-2020, 08:58 PM Thread Starter
agh3092
Junior Member
agh3092's Avatar
Originally Posted by wjkeith View Post
Do you have rain sensing wipers?
http://www.wjjeeps.com/rainsense.htm
I do not have those on mine.
agh3092 is offline
post #17 of 24 Old 04-05-2020, 08:25 AM
jtec
jtec's Avatar
2014 JK Wrangler
the BCM supplies a ground to the control side of relays (#85) we need to see if BCM is in control or relays.
SO with KOEO wipers selected lets look at HI speed to start, is 85 a ground?
then select different speeds for a quick confirmation..
This was a NEW wiper motor?
If not we may have to validate the part as good on vehicle.
jtec is offline
post #18 of 24 Old 04-05-2020, 02:18 PM Thread Starter
agh3092
Junior Member
agh3092's Avatar
85 shows 12 volts in high and low positions.
87 ground.
87A groundin high position, but not low.
The wiper motor in new. I have a pigtail and can run it one speed and works just like my old one
now I have a spare.lol.
MFS....KOEO
#7 showed 5.9 volts, is this residual voltage?
#8 0 volts.
MFS....KOEO
#8 0 volts.
agh3092 is offline
post #19 of 24 Old 04-05-2020, 03:29 PM
jtec
jtec's Avatar
2014 JK Wrangler
jtec is offline
post #20 of 24 Old 04-06-2020, 02:38 PM Thread Starter
agh3092
Junior Member
agh3092's Avatar
I have voltage on both # 85 positions, is it possible I'm not looking at the diagram correctly as you have said # 85 should be a ground. I got a feeling that I'm the one making a mistake on the numbering. I will see if I can post a drawing on the forum. Thanks again for all of your help. Below is what I have so far, not professional but hopefully will show what I have and where.
agh3092 is offline
post #21 of 24 Old 04-10-2020, 09:40 AM
jtec
jtec's Avatar
2014 JK Wrangler
#85 should be a ground. This is how the BCM energizes the relay.The BCM grounds this wire.
#86 should be 12v, this and above (#85) are the control side of relay.
When the BCM grounds #85 the relay closes and 12v is then present on #87.
jtec is offline
post #22 of 24 Old 04-10-2020, 11:11 AM Thread Starter
agh3092
Junior Member
agh3092's Avatar
Two questions.
1. Do I have the numbers correct as is 85 shown were I have it in the drawing?
2. Could the BCM cause this issue? (everything else works except the front wipers)
Thank you.
agh3092 is offline
post #23 of 24 Old 04-10-2020, 11:22 AM
jtec
jtec's Avatar
2014 JK Wrangler
The attached PDC pin out should help ID which cavity is what #.
I want to ask again - you did remove the IOD fuse count to 10 then replace it?
Thats my secret BCM reset hail mary.
jtec is offline
post #24 of 24 Old 04-10-2020, 02:25 PM Thread Starter
agh3092
Junior Member
agh3092's Avatar
I checked the IOD once again and let it reset. All fuses have removed and checked separately. I have remove and switched around relays. There is a light blue wire that I notice was taped off and not attached. It looks to comes out of the main harness that goes through the firewall. Any idea what this goes to? It is a factory wire as I can see it intertwined in the harness from firewall. It looks like it has been pulled out if the back of the fuse block.
agh3092 is offline
