WJ Windshield Wipers Issues - JeepForum.com
post #1 of 24 Old 03-29-2020, 08:48 PM Thread Starter
agh3092
Junior Member
agh3092's Avatar
I am currently having issues with my 04 GC, the windshield wipers are not working and it doesn't seem to be an easy fix. I have replaced the motor as well as the multi function wiper switch. I do know the wiper motor is working as I can get one speed out of it by applying 12v to it which I have done.
Also the windows on the passenger side don't work nor do the locks from that side. What actually controls the wiper system? As it seems I am replacing one part of the system at a time so whats next? At this point I am open to any ideals.
Thanks.
agh3092 is offline
post #2 of 24 Old 03-29-2020, 09:54 PM
2oldjeeps
ill look in my haynes manual. may get back tomorrow. when i buy a "new" jeep i stop at a zone and get the haynes book. it helps most of my wire problems
99wj,143,000 miles
00xj,177,000 miles
10hummer3,74,000 miles
98xj,130,000 miles
2oldjeeps is offline
post #3 of 24 Old 03-30-2020, 12:35 AM
Uniblurb
Uniblurb's Avatar
Have you checked or changed out C1 (circuit breaker 1, 20amp, wipers) in the fuse/junction block on the far left underside of the dash? Here's a diagram of the box and it should be on the top right.
http://www.wjjeeps.com/fuses.htm
On the passenger side windows/locks not working check the boot for cuts/broken wires on the passenger side front door jam. It's also a good idea to check the driver's door jam wiring for breaks/cuts since they're more common on the driver's door since it's used more.
2004 4.7L WJ Limited, 96 4.0 ZJ
Uniblurb is offline
post #4 of 24 Old 03-30-2020, 09:52 AM Thread Starter
agh3092
Junior Member
agh3092's Avatar
I switched the C1 and C2 around and checked both breakers as well. I put them back in original slots as well.
Most likely something simple when its all said and done with.
Thanks for your reply.
agh3092 is offline
post #5 of 24 Old 03-30-2020, 10:06 AM
jtec
jtec's Avatar
2014 JK Wrangler
You switched relays- is all OK now? IDK?
Do we need toget the diagrams out?
jtec is offline
post #6 of 24 Old 03-30-2020, 11:15 AM Thread Starter
agh3092
Junior Member
agh3092's Avatar
Sorry about that slip up. No they are still not working. And the rains are getting closer. LOL. The BCM might be in its future as it seems I am replacing one piece at a time.
agh3092 is offline
post #7 of 24 Old 03-30-2020, 12:31 PM
jtec
jtec's Avatar
2014 JK Wrangler
the front wipers do not work, hi lo or intermittent ?
Does washer or pulse operate?
rear ok?
jtec is offline
post #8 of 24 Old 03-30-2020, 12:50 PM
jtec
jtec's Avatar
2014 JK Wrangler
aT wiper control relay in PDC lets see if BCM is controlling wiper relays.
cavity 86 have 12v and check if cavity 85 is a good ground.
jtec is offline
post #9 of 24 Old 03-30-2020, 03:10 PM Thread Starter
agh3092
Junior Member
agh3092's Avatar
Jtec,
Just checked and I do have voltage on 87 and good ground on 85.
Yes its my front wipers that don't work. The front washer works and the rear wiper and washer works as well. Just my front wipers are out on any speed. I have replaced the motor with a know working one as well as the switch.
agh3092 is offline
post #10 of 24 Old 03-30-2020, 03:31 PM
jtec
jtec's Avatar
2014 JK Wrangler
ok lets be sure we are answering questions. Yeah I left out some details and its all details.
There are 2 relays - With KOEO did you confirm NO ground on BOTH cavitys #85?
I will get the diagrams pulled up and look for next step.
jtec is offline
post #11 of 24 Old 03-30-2020, 04:38 PM
jtec
jtec's Avatar
2014 JK Wrangler
check for 12v at relay cavity 86 and 87 on off relay and 86 on low high relay.
starting in junction box (in cab fuse box)
check fuse #7, #22, #28 #29 Do not just look at it.
multi function switch, turn on wiper low or hi is terminal 8 and 7 showing 12v?
remind me - you did do my hail mary with IOD fuse?
jtec is offline
post #12 of 24 Old 04-03-2020, 04:30 PM Thread Starter
agh3092
Junior Member
agh3092's Avatar
Jtec and others,
On the #32 wiper on/off relay I have 12.9 volts on #87. 12.9 volts on #85.
#87A shows ground. 30, 86, 87 all show 0 voltage.
On the #33 High/low relay I have 12.9 volts on #85. 87A shows ground.
30, 86, 87A all show 0 voltage.
These readings were all taken with KOEO.
Looking forward to your reply.
agh3092 is offline
post #13 of 24 Old 04-04-2020, 12:25 PM Thread Starter
agh3092
Junior Member
agh3092's Avatar
IOD Fuse good.
Inside fuse panel 7, 22, 28, 29 all good.
Multi function switch... Terminal 7 shows 5.9 volts
Terminal 8 shows 0
Jtec and others,
agh3092 is offline
post #14 of 24 Old 04-04-2020, 12:31 PM Thread Starter
agh3092
Junior Member
agh3092's Avatar
IOD Fuse good.
Terminal 8 shows 0
Jtec and others,
On the #33 High/low relay I have 12.9 volts on #85. 87 shows ground.
agh3092 is offline
post #15 of 24 Old 04-04-2020, 07:09 PM
wjkeith
wjkeith's Avatar
Do you have rain sensing wipers?
http://www.wjjeeps.com/rainsense.htm
wjkeith is offline
