WJ Spring Perch repair Walkthrough. - JeepForum.com
 6Likes
post #1 of 21 Old 03-16-2014, 01:48 PM Thread Starter
illuzioun
2003 WJ
Perhaps this could be a sticky, as this repair is relatively common.
As seen in my build thread, I had a very rusty spring perch on the front passenger side. I figured I'd make a write up on how to fix it so it's easier to find.
This is what my passenger side spring perch had looked like after I pulled off the spring.
I thought of a bunch of different ideas on how to fix the perch, but basically decided to replicate the factory perch to the best of my abilities. There's a couple different ways to achieve the same result, but I decided it was best to just go with the same measurements of the factory perch.
The factory perch is roughly 1/8'' thick. It's hard to measure the thickness after it's been rusted. 1 3/4'' tall with a 3 1/4" Diameter.
I went to work and grabbed a piece of 1/4" thick 3 1/4" diameter pipe. I then torched out a circle in a piece of 1/4" steel and capped off the top of the pipe. This is the fab work of the new perch.
I then ground down the old rusty spring perch on the axle to as flat as a service as I could.
This is a quick mock up before I welded it.
And finally, after paint and welding.
Hopefully someone can use this to fix their own rusty or broken spring perches! Enjoy.
illuzioun is offline
post #2 of 21 Old 03-16-2014, 04:02 PM
Vaporhead
Sounds like a job for a machinist. Glad I don't got rust like that. Good work though.
Vaporhead is offline
post #3 of 21 Old 03-16-2014, 05:20 PM Thread Starter
illuzioun
2003 WJ
Anybody that knows how to weld can do this. Grind, clean, weld. It's really not a hard job.
post #4 of 21 Old 03-16-2014, 06:05 PM
Johnyre
Agreed!!
As I roll down the trail,I hope my traction will not fail.But if I spin & begin to slide,please dear lord protect my ride
https://
http://fortcollinswheelers.com
Johnyre is offline
post #5 of 21 Old 03-16-2014, 06:08 PM
derekmac
derekmac's Avatar
Thanks for posting this! I'm sure when I go to do my lift down the road, I'll need to do mine as well.
2005 TJ Rubicon
derekmac is offline
post #6 of 21 Old 03-16-2014, 07:23 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Good thread and pics. I'm adding this to the FAQ thread.
~Richard
billzcat1 is offline
post #7 of 21 Old 03-16-2014, 07:34 PM
evilcairn
Nice one , thanks for the guide.
WJ 2001 V8 , 6.5" lift IRO , 35" BF , Front DS TomWoods mutilCV, Fender Iceland, TrueTrac Eaton Front, Gears 4:56 , Custom Front bumper, custom rock slidder ....
evilcairn is offline
post #8 of 21 Old 03-16-2014, 08:13 PM
dlundblad
2003 WJ
That is basically what I did with mine.. Well what I had done. Lol. What kind of paint did you use?
03 WJ Laredo 4.Sl0w
2" BB-Overland Skids
IPF 868 lights-197K
245/75/16 GY DuraTracs
dlundblad is offline
post #9 of 21 Old 03-16-2014, 09:15 PM Thread Starter
illuzioun
2003 WJ
post #10 of 21 Old 03-30-2014, 04:01 PM
mtennwj
Do you have to disconnect anything when you are welding these on like the battery or computer etc?
2000wj limited quadra drive 129k
2000wj Laredo 2wd 235k
mtennwj is offline
post #11 of 21 Old 03-30-2014, 04:36 PM
js12278
Welding. A skill all real men should learn.
js12278 is offline
post #12 of 21 Old 03-30-2014, 04:49 PM
StrokedWJ
StrokedWJ's Avatar
As a general rule its always a good idea to disconntect the battery when welding. I have however, welded on mine several times with everything connected with no ill effects.
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #13 of 21 Old 03-31-2014, 11:04 AM
mtennwj
Not trying to hijack the thread but my dad has a wire welder and will be doing the welding if I just disconnect the battery It should be ok should I pull the brake lines out of the way?
mtennwj is offline
post #14 of 21 Old 03-31-2014, 11:12 AM
ThaBeefs
i wouldnt pull them out of the way .... just lay something over them for protection will be good enough.
SOLD 02 WJ 4inch RCX 265-70-17 17x9 DCs
New 01 WJ Stock ... For now
ThaBeefs is offline
post #15 of 21 Old 04-01-2014, 12:01 PM Thread Starter
illuzioun
2003 WJ
Yes make sure to disconnect battery. I welded mine up with only taking the brake lines off. I never disconnected them entirely. Just the brackets so I could wire tie them out of the way more.
