WJ selec trac linkage broke, need help - JeepForum.com
post #1 of 4 Old 07-25-2015, 10:15 PM Thread Starter
Tman96
Awhile ago the linkage to my select trac transfer case on my 2003 4.0 grand cherokee. I'm not sure what you call it but right where it connects to the transfer case lever the pin or bolt that was there snapped. I was wondering what it would cost to fix, as I'm sure you all know space is very tight in this spot, so I don't have the tools to drill the pin/bolt out and put in a new one. I'm wondering if a shop could do it without having to drop the whole case just to get to it. Also if anyone could find the part that would be great because I can't source one. If the pictures post basically the golden looking price needs to be connected to a hole in the top of the lever circled in red.
Tman96 is offline
post #2 of 4 Old 07-26-2015, 09:59 AM
StrokedWJ
StrokedWJ's Avatar
The shifter cable just pushes onto the shift arm. You should be able to reach up there an pop the remaining piece of the pin out by hand. I can't remember exactly, but I think the shift cable was the female end, and the shift arm was the male end. You can remove the shifter arm by unbolting the bottom bolt you see in the picture, pull it down and replace it if that is the part that is broken. I replaced the shifter linkage a few years ago let me see if I can find the part #.
edit:
Here is an old post of mine with some more pictures https://www.jeepforum.com/forum/f310/tc-parts-1076164/. The shift arm lever is part # 05012307AA. I believe the cable is part #52104218AB.
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #3 of 4 Old 07-26-2015, 10:22 AM Thread Starter
Tman96
Ok thanks I'll get under there and take that shifter arm off so I can see what exactly needs done.
Tman96 is offline
post #4 of 4 Old 07-28-2015, 07:06 AM Thread Starter
Tman96
Originally Posted by StrokedWJ
The shifter cable just pushes onto the shift arm. You should be able to reach up there an pop the remaining piece of the pin out by hand. I can't remember exactly, but I think the shift cable was the female end, and the shift arm was the male end. You can remove the shifter arm by unbolting the bottom bolt you see in the picture, pull it down and replace it if that is the part that is broken. I replaced the shifter linkage a few years ago let me see if I can find the part #. edit: Here is an old post of mine with some more pictures https://www.jeepforum.com/forum/f310/tc-parts-1076164/. The shift arm lever is part # 05012307AA. I believe the cable is part #52104218AB.
i got it off and need to replace the shift arm. Thank you for the part number and site. I tried to shop around a little but that was the only place that had it.
Tman96 is offline
