WJ’s and manual brake bleeding - JeepForum.com
 11Likes
  • 1 Post By DJCantonGA
  • 3 Post By 2oldjeeps
  • 1 Post By Photoweborama
  • 2 Post By BrokeJeepJoe
  • 2 Post By Wabatuckian
  • 1 Post By Wabatuckian
  • 1 Post By 99wjtx
post #1 of 14 Old 04-02-2020, 07:14 PM Thread Starter
Photoweborama
Photoweborama's Avatar
Can you manually bleed the brakes on a WJ, or is there something that makes you use a pressure bleeder?
Sent from my iPhone using Tapatalk
Photoweborama is online now
post #2 of 14 Old 04-02-2020, 08:50 PM
DJCantonGA
DJCantonGA's Avatar
I'm planning on doing my front brakes tomorrow, and I'll bleed all 4 when I'm done. The fluid needs replacing. I'm using a vacuum pump I picked up at HF. There are several good YT videos, it's not a bad job at all.
By manually, are you referring to gravity bleeding? If so, you can, and there are good videos on that method as well.
Klarah523 likes this.
DJCantonGA is offline
post #3 of 14 Old 04-02-2020, 09:35 PM
2oldjeeps
i use a solid 4 inch cement block on the pedal, bleed,close. pump and set block, bleed. repeat till done. one man job.
DJCantonGA, 99AZWJ and Klarah523 like this.
99wj,143,000 miles
00xj,177,000 miles
10hummer3,74,000 miles
98xj,130,000 miles
2oldjeeps is offline
post #4 of 14 Old 04-03-2020, 09:46 AM Thread Starter
Photoweborama
That’s how I used to do it years ago, except I’ll be replacing the cement block with my son..
I have to replace calipers on my WJ this time and I wasn’t sure if this method was still possible on these “new fangled” cars...
post #5 of 14 Old 04-03-2020, 01:05 PM
BrokeJeepJoe
BrokeJeepJoe's Avatar
I replaced the front to rear line recently. Gravity bled the rears and then the fronts. I bleed brakes a little different than most. I don't pump the pedal and hold, I open the bleeder and push the pedal down and hold then close the bleeder. This is all after gravity bleeding. Learned that method from an old timer when I was in my teens which was many many decades ago and it hasn't failed me yet on any vehicle I've worked on ABS or not. I also replaced every line on my YJ and TJ and used this method without fail. Just make sure you have good flow when gravity bleeding. Patience is the key!
2oldjeeps and Bigrigr like this.
BrokeJeepJoe is offline
post #6 of 14 Old 04-03-2020, 04:17 PM
Wabatuckian
Wabatuckian's Avatar
I've done both power bleeding (with a hand pump) and manual bleeding on my WJ. No problems with either method.
Photoweborama and Klarah523 like this.
Wabatuckian is offline
post #7 of 14 Old 04-06-2020, 09:57 AM Thread Starter
Photoweborama
So I watched the gravity bleeding videos. Seems simple.
Is there any advantage between the regular manual and gravity bleeding?
post #8 of 14 Old 04-07-2020, 08:46 AM
Wabatuckian
Gravity bleeding = slow, least work, requires one person
Manual bleeding = faster, most work, requires two people
Suction bleeding = fastest, medium work, requires one person with equipment; most expensive
Josh
Bigrigr likes this.
post #9 of 14 Old 04-09-2020, 10:19 AM
99wjtx
99wjtx's Avatar
Mighty Vac hand pumps work great but quite a bit less so after sitting in a plastic storage bin unused for 10 years between jobs - especially when they hadn't been cleaned thoroughly before being put away.
Photoweborama likes this.
Rage! Rage against the dying of the Jeep.
99 WJ Limited 4.7/NV247
01 WJ Laredo 4.7/NP242
99wjtx is offline
post #10 of 14 Old 04-09-2020, 02:49 PM
Wabatuckian
I found one from the '90s I had left in my parents' garage. It still worked fine after putting a bit of oil in it to lube the seals. It wouldn't move otherwise.
Josh
post #11 of 14 Old 04-10-2020, 11:18 AM
FanTech
I have one and it works great, when it seals. The vacuum cup doesn't want to seal all that well. Fittings/tubing could be better as well but it still works.
FanTech is offline
post #12 of 14 Old 04-25-2020, 10:16 AM
coldspit47
Can also make a one-man bleeder for manual bleeding out of an old (clean) gatorade bottle, and some aquarium tubing if your helper happens to be busy. drill a hole in the cap of the bottle, shove the tubing through the hole all the way to the bottom of the bottle, drill a tiny air relief hole in the cap. fill bottle about 1/4 to 1/3 of the way with clean fluid.
Never had any issues with manual or one man bleed, can be done pretty easily without even raising it. Just as easy to flush, I did it this way last brake job, may just flush every brake change since it doesn't get driven that much anymore and it's so easy.
If you're replacing calipers, you might as well replace brake hoses if they're original. Front hoses are easy (though mildly tedious), haven't done rears yet.
04 WJ NV242, IRO 3in, bilsteins, IRO adj UCAs/LCAs/A arm, 265/75/16 Laufenn Xfit, 4.56 gears
coldspit47 is offline
post #13 of 14 Old 04-27-2020, 06:48 AM
Sc_trini
I did all 4 corners using a Pneumatic Bleeder from Harbor Freight. It costs about $40 at most and I was able to do the job myself in an afternoon.
Sc_trini is offline
post #14 of 14 Old 04-27-2020, 10:51 AM Thread Starter
Photoweborama
So many options, and even the expensive ones aren’t that expensive...
