WJ Repair madness! - JeepForum.com
post #1 of 17 Old 03-10-2011, 05:25 PM Thread Starter
xJoshxx
xJoshxx's Avatar
2012 WK
WJ Repair madness!
So on the agenda for this weekend.
Is New radiator OEM from Nick.
New Coolant Hose's
New steering box mine' been seeping for months making a mess finally getting on my nerves.
New Power Steering Pressure Hose
New Power Steering Return Hose
Magnetic Inline Power Steering filter
Power Steering Cooler
Hayden 679 Stacked plate Transmission cooler. (anybody think this is too big was on the only one my parts place had in time). i drive pretty spirited and i'm sure having tires that are 3" bigger than stock don't help the helpless 42re
3/4 x 11-5/8 x 11 Extra Heavy Duty
Series Rapid-Cool
Style Plate & Fin
Thickness 3/4
Height 11-5/8
Length 11
Core Length 9-1/2
Fitting 3/8Push-on
Finish Black
anybody want pictures? or how too.
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #2 of 17 Old 03-10-2011, 06:08 PM
FleshEater
2014 JK Wrangler
Hey man funny I just saw a really easy and great upgrade for the 42RE cooler over on Mall Crawlin'. Might want to check it out before you get into that; it's about two times bigger than the stock one and takes almost no fabricating to bolt up.
Not sure which part they replaced the OEM with but it's in the FAQ/Write Up section.
Hope this is helpful.
2014 JKU Rubicon *DAILY DRIVER*
Gone but not forgotten; 2005 LJ *SOLD* 1987 XJ *SOLD* 2002 WJ *SOLD* 1995 ZJ *SOLD*
FleshEater is offline
post #3 of 17 Old 03-10-2011, 06:11 PM Thread Starter
xJoshxx
xJoshxx's Avatar
2012 WK
Yea im keeping the Stock in Radiator cooler as-well. once i replace all this crap my WJ will be knock on wood un overheatable
i already have a heavy duty Fan clutch E-FAN 180 degree tstat can wait to see all the **** that comes out my heater core.
2011 WK2 ORA2 sold
xJoshxx is offline
post #4 of 17 Old 03-10-2011, 06:17 PM
FleshEater
2014 JK Wrangler
Do you wheel in mud or tow? My YJ buddy suggested up dating my fan, radiator and cooling system for when I sink it and have to feed it some heavy skinny pedal to get out. If it seems like a necessary upgrade off to searching I go.
post #5 of 17 Old 03-20-2011, 07:57 PM Thread Starter
xJoshxx
xJoshxx's Avatar
2012 WK
Updates
GD PITMAN ARM I couldn't get it off. 3/4" impact 1500FT heat no go.
Nothing a sawzall can't cure
Oh and btw guys a new pitman is $21 so just cut the SOB OFF
2011 WK2 ORA2 sold
xJoshxx is offline
post #6 of 17 Old 03-21-2011, 09:02 PM
snobrdrkid07
snobrdrkid07's Avatar
Okay, So I am understanding the radiator system in the WJ's here...
cause I have the two package and thought that I already had a transmission cooler with the mechanical fan and the e-fan??
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600s | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100s | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #7 of 17 Old 03-21-2011, 09:08 PM Thread Starter
xJoshxx
xJoshxx's Avatar
2012 WK
One is the A\C Condenser,
Yes you already have a trans-cooler built into the Radiator, being lifted 3" bigger tires than stock and a heavy right foot will help the already helpless 42re
i have the external cooler in addition to the radiator one.
Power steering cooler just idling it was reaching 100+degrees. header sits right next to the power steering pump. bigger tires more work = more heat. I also added a Magna-Pure power steering filter.
Im going to have to move my power steering cooler unfortunately when i put the upper radiator support back on it hits..
Reason the tubes are so long Getting tubes onto Tube and FIN coolers SUCK ***. plus i wanted it more in the path of the fan. heavy duty clutch ftw.
2011 WK2 ORA2 sold
xJoshxx is offline
post #8 of 17 Old 03-21-2011, 09:11 PM
snobrdrkid07
Oh, did not know about the A/C condenser. What do you mean built in? Sorry if that is a silly question. Did you not have the tow-package?
Good idea on the Power steering cooler. Definitely cant hurt!
-Michael-
post #9 of 17 Old 03-21-2011, 09:16 PM Thread Starter
xJoshxx
xJoshxx's Avatar
2012 WK
inline 6's did not get an external cooler even if you had the tow package you get a electric fan and a mechanical fan
the stock setup use's part of the radiator for a transmission cooler
2011 WK2 ORA2 sold
xJoshxx is offline
post #10 of 17 Old 03-23-2011, 06:10 AM
FleshEater
2014 JK Wrangler
Josh what model is the 679 for? I found this through Summit...$55 isn't bad for a priceless upgrade.
http://www.summitracing.com/parts/HDA-678/
Have you also installed a transmission temperature gauge?
post #11 of 17 Old 03-23-2011, 12:48 PM Thread Starter
xJoshxx
xJoshxx's Avatar
2012 WK
i went with a smaller model. the 677 the 678,679 are 11x9 and 11x11 way to large for me.
2011 WK2 ORA2 sold
xJoshxx is offline
post #12 of 17 Old 03-23-2011, 06:20 PM
FleshEater
2014 JK Wrangler
Oh...I only read the first post to double check where you were asking about the 679. Is it too large because it doesn't fit with fabricating or because it's overkill?
Sorry for the questions but I haven't researched this much yet.
post #13 of 17 Old 03-23-2011, 06:56 PM
TheBoss
TheBoss's Avatar
2004's without tow pack. have the trans. sharing the condensor as a cooler and only an electric fan. Let us know how your cooler works I'll be adding one soon.
TheBoss is offline
post #14 of 17 Old 03-23-2011, 07:02 PM
snobrdrkid07
So what does the 2004 I6 with the tow package have? Mechanical fan, electric fan, and transmission cooler built into the A/C condenser?
-Michael-
post #15 of 17 Old 03-23-2011, 07:09 PM
TheBoss
TheBoss's Avatar
Dunno, I added my factory hitch not sure if they route it through the rad. or the condensor. Either way a aux. cooler should be added. I'm still looking around to find the right size.
TheBoss is offline
Grand cherokee 4.7 misfire madness! BigM1 WJ Grand Cherokee Forum 11 07-13-2012 02:45 PM
Repair manuals? Jason_alex WJ Grand Cherokee Forum 7 01-24-2011 03:49 PM
First repair on your own? kristi5683 WJ Grand Cherokee Forum 31 01-17-2011 11:33 AM
Front Fender Repair trm7655 WJ Grand Cherokee Forum 4 01-14-2011 03:53 PM
Muffler repair? jpilk99 WJ Grand Cherokee Forum 8 01-04-2011 02:43 PM
