WJ Rear Speakers: Does an exact replacement size exist? - JeepForum.com
 1Likes
  • 1 Post By SoCal2004wj
post #1 of 14 Old 06-13-2021, 08:43 PM Thread Starter
Jeepsmsc2
WJ Rear Speakers: Does an exact replacement size exist with correctly positioned screw holes to screw into the door without modification? Want to avoid using a smaller speaker size nestled within an adapter bracket.
Apparently the rear OEM speakers are 6.75". Is this correct?
Jeepsmsc2 is offline
post #2 of 14 Old 06-13-2021, 08:53 PM
SoCal2004wj
SoCal2004wj's Avatar
I recently replaced the rears with some Infinity 6.5" that came with an adapter that worked perfectly for the stock door enclosures. In reality, you're not going to notice a difference between 6.5" and 6.75". BTW - they sound much cleaner than stock
Jeepsmsc2 likes this.
SoCal2004wj is offline
post #3 of 14 Old 06-13-2021, 09:01 PM Thread Starter
Jeepsmsc2
Thanks do you have the a link or SKU handy to the one you bought?
post #4 of 14 Old 06-13-2021, 09:46 PM
SoCal2004wj
I bought them some years back, but the model number at the time was 6032cf. According to Crutchfield, the current replacement speaker is 6532ex.
https://www.crutchfield.com/p_108R65...EF-6532ex.html
Hope it helps!
post #5 of 14 Old 06-13-2021, 11:05 PM Thread Starter
Jeepsmsc2
Thanks!
post #6 of 14 Old 06-14-2021, 02:16 AM
underscore
I haven't done it myself, but when I was digging around I saw a few people saying stock JK and WK speakers have the same fitment, so one of the optional upgrade sets from those might be a nice step up.
00 WJ
[x] 07 WK CRD/OME/MALONE 1.5 [x] 00 XJ/OME [x] 97 TJ [x] 92 YJ
underscore is offline
post #7 of 14 Old 06-14-2021, 08:01 PM
Golden-Arm
Golden-Arm's Avatar
factory infinity speakers are available. https://www.jeeppartsoverstock.com/p...5081669AC.html
nothing fits better than stock. https://www.oemautosound.com/p-516-i...6038657aa.aspx
Uphill Slow, Downhill Fast, Tonnage First, Safety Last!
Golden-Arm is offline
post #8 of 14 Old 06-15-2021, 10:13 AM Thread Starter
Jeepsmsc2
So are those the OEM speakers used for the Laredo? Or the Limited with the upgraded sound? I have Laredo and want to improve the original speakers? Thanks
post #9 of 14 Old 06-15-2021, 12:23 PM
xcaliber81
xcaliber81's Avatar
The top link shows a 6 by 9 in the image.
xcaliber81 is offline
post #10 of 14 Old 06-15-2021, 01:29 PM
Vaskania
Vaskania's Avatar
3rd and 4th image show the round speaker. I can't tell which speaker that listing is selling.
/following thread- relevant to my interests
'05 KJ Renegade 4x4 [RIP 12/28/2018]
'01 WJ Limited 4x4 4.7L
Vaskania is offline
post #11 of 14 Old 06-15-2021, 02:07 PM Thread Starter
Jeepsmsc2
I pulled out the rear OEM Mopar speaker in my Laredo. It's an "Oxford" brand, made in USA.
post #12 of 14 Old 06-15-2021, 04:39 PM
xcaliber81
xcaliber81's Avatar
I put the kenwood KFC-XP6902C component speakers in the front and almost right away i heard something cutting out thinking it was my new ones it eventually went away lol turns out im in the market for rear speakers now, my jeep is hating life this year.
post #13 of 14 Old 06-15-2021, 06:57 PM
Golden-Arm
Golden-Arm's Avatar
you can buy the 2.5 dash speakers, the 6x9 front door speakers and the round 6.75 for the rear doors. these are all infinity speakers, used with the premium infinity amp system. if you can find one, chrysler also made a giant bass speaker, amp and cabinet, that mounted behind the rear seats.
post #14 of 14 Old 06-16-2021, 04:29 PM Thread Starter
Jeepsmsc2
Appreciate feedback. In case someone comes across this thread in the future, I installed this for the rear:
REAR SPEAKERS: Pioneer TS-G1620F (requires 6.5" to 6.75" adapter bracket)
REAR ADAPTER BRACKET: METRA 82-6600
REAR WIRING HARNESS: METRA 72-6514
Lessons learned:
A) Roll the window down to make sure it doesn't "grab" the wiring harness and unplug the speaker. I used some friction tape to tape the slack in the wire to the speaker and door to prevent the wire from getting yanked out by the window.
B) if using the Metra wiring harness, they slip on the speaker terminals without solder. Use needle nose pliers and squeeze them after slipping them on. This will make for a more permanent connection.
