WJ pulling 9 O2 sensor codes? - JeepForum.com
post #1 of 3 Old 07-11-2019, 03:22 PM Thread Starter
alex9
2003 WJ
Unhappy WJ pulling 9 O2 sensor codes?
Hey everyone! I have a 2003 WJ 4.7L V8 that has recently been getting terrible gas mileage (9mpg) and doesn't have as much power as it used to.
I turned the key 3 times and the codes I'm getting are P0031, P0051, P0132, P0152, P0138, P0158, P0131, P0136, and P1499.
Since all of these popped up at once it makes me think that it's a bigger problem than just the O2 sensors. Has this happened to anyone? I have no idea what the problem could be.
alex9 is offline
post #2 of 3 Old 07-11-2019, 05:28 PM
jtec
2014 JK Wrangler
all likely wiring issues, have you looked at wiring and connectors on the indicated components - Have you driven in water, off road, any recent work ?
I have seen rodents create a mess of wiring, If you can a SCAN may show more codes hopefully help explain.
group the codes
P0031-1/1 O2 SENSOR HEATER CIRCUIT LOW
P0051-2/1 O2 SENSOR HEATER CIRCUIT LOW
P0131-1/1 O2 SENSOR SHORTED TO GROUND
P0136-1/2 O2 SENSOR HEATER CIRCUIT MALFUNCTION
P0132-1/1 O2 SENSOR SHORTED TO VOLTAGE
P0138-1/2 O2 SENSOR SHORTED TO VOLTAGE
P0152-2/1 O2 SENSOR SHORTED TO VOLTAGE
P0158-2/2 O2 SENSOR SHORTED TO VOLTAGE
jtec is offline
post #3 of 3 Old 07-11-2019, 06:04 PM
RoccoRacer
You probably have a short somewhere. Also check your fuse box, location 16 is probably blown.
https://images.app.goo.gl/ACruSFiszKEurKXb9
Sent from my iPhone using Tapatalk
2001 Jeep Grand Cherokee Limited, "Chewbacca"
RoccoRacer is offline
