WJ Power Windows and Locks - JeepForum.com
post #1 of 9 Old 10-13-2019, 04:11 PM Thread Starter
doozis1221
The passenger side power locks and windows suddenly stopped working on my 2004 WJ , drivers side work ok. I read all about the broken thru the door wires and I checked them all carefully and that is not the problem.
I check positive and negative wires at both sides and all seems fine there. I also replaced the Main driver side control module and It made no difference. The driver side door lock and window work fine and the rear driver side window works fine but no
other locks or windows work. I tested each wire in both door boots for good continuity and they are fine. The black ground wire is well grounded and the Orange power wire has a good 12 v at the connector.
Any suggestions would be greatly appreciated
Thanks
Steve
doozis1221 is offline
post #2 of 9 Old 10-13-2019, 09:31 PM
glbear
Junior Member
does the rke work,if not working its probably the passenger door module
glbear is offline
post #3 of 9 Old 10-14-2019, 09:22 AM Thread Starter
doozis1221
rke ?
Not sure what rke is
sorry
Steve
post #4 of 9 Old 10-14-2019, 09:48 AM Thread Starter
doozis1221
Just found out....rke = remote keyless entry.....and NO my rke does not work...….
Many thanks
I'll check the passenger side module next
Steve
post #5 of 9 Old 10-14-2019, 10:04 PM
glbear
Junior Member
its been 6yrs since I replaced the module in my 2004, I think the only way to test module is with a drb111 scan tool,if I remember correctly
glbear is offline
post #6 of 9 Old 10-15-2019, 06:45 AM
grandboost98
grandboost98's Avatar
Steve
Im going through the same issue, keep us posted!
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #7 of 9 Old 10-15-2019, 11:28 AM
glbear
Junior Member
if module is replaced it will need to be programed at jeep dealer with a drb111 scan tool for the rke to work
glbear is offline
post #8 of 9 Old 10-17-2019, 09:07 AM
Mattyjm
Mattyjm's Avatar
Many thanks
Steve
If I were you, I'd walk a junkyard and find a WJ with a passenger side door module and a keyfob hanging from the steering column. Get the module and matching fob from the same WJ and your problems should be solved.
2002 Laredo. Baloo.
2004 Rocky Mountain Edition. Froggy Bandit. Wife's Daily Driver. PRISTINE! Stock height and may stay that way.....
Mattyjm is offline
post #9 of 9 Old 11-03-2019, 09:20 PM Thread Starter
doozis1221
turns out …..It was the passenger side window/lock module.
I got one on Ebay for 35.00 and it fixed it , all windows and locks work fine but I will
have to get a lock smith or Jeep dealer to program my keyfobs. This is not an issue for
me because I can live without keyless entry.
Thanks for the help , I greatly appreciated it !!
Steve
